July 9, 2012, 10:46 |
Calculate Cell Centre to Cell Face Distances
Edward Leonard
Rep Power: 13 |
I'm in need of finding the distance from every cell center to the center of each of its faces. I've been able to use the utility in
$FOAM_APP/utilities/postProcessing/miscellaneous/writeCellCentres Code:
surfaceVectorField cf ( IOobject ( "cellFaces", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh.Cf() ); cf.write(); |
July 9, 2012, 11:41 |
Tomislav Maric
Rep Power: 21 |
Cf is a field that is stored within the mesh. It is done using lazy evaluation: the field is evaluated once, meaning that there is a dynamic memory allocation taking place, so that when you call mesh.Cf() multiple times (no changes to the mesh assumed), it will not be re-calculated.
For this reason, you need only a const ref to the field: Code:
const volVectorField& Cf = mesh.Cf(); The cell centres you get in the same way: Code:
const volVectorField& C = mesh.C(); Code:
const surfaceVectorField& Cf = mesh.Cf(); const volVectorField& C = mesh.C(); surfaceScalarField faceCellDist ( IOobject ( "faceCellDist", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar ( "0", dimLength, scalar(0) ) ); const labelList& own = mesh.owner(); forAll (own, I) { faceCellDist[I] = Foam::mag(C[own[I]] - Cf[I]); } faceCellDist.write(); This will only run in serial and access the distance to the cell that owns the face. If you need the distance to the neighbour as well, you can store both values in a surfaceVectorField, and keep the third component of the vector untouched. This way, you have an overhead in a value per face, but you don't get into writing GeometricFIeld<Pair, ... > . If space is a constraint (doubt it), you can have a List<Pair> with both owner-cell-face, neighbour-cell-face distance stored in a Pair. The length of the List will be equal to the number of faces to the mesh. For parallel stuff, you need to go over boundaries and access some data accross it, and then you have the same problem that I posted regarding Pstream: you will need to communicate distances across patches "at the same time". Tomislav |
July 9, 2012, 12:04 |
Steven van Haren
Rep Power: 15 |
I would take a look in:
src » finiteVolume » interpolation » surfaceInterpolation » surfaceInterpolation» surfaceInterpolation.C The makeWeights function is almost what you need I think. |
July 9, 2012, 13:35 |
#4 | |
Tomislav Maric
Rep Power: 21 |
July 9, 2012, 14:39 |
Steven van Haren
Rep Power: 15 |
July 10, 2012, 14:58 |
#6 | |
Edward Leonard
Rep Power: 13 |
I like the idea you've put forth here, but unfortunately compilation failed on this as well. I've attached the error output as well as the code written thus far. It seems to complain about an incorrect usage of surfaceScalarField. I appreciate all input! Thanks, ~Ed |
July 10, 2012, 15:32 |
Tomislav Maric
Rep Power: 21 |
it compiles on my laptop, either I posted something wrong in the code or you copied wrong. Anyhew, I'm using 2.1.x, but for this, it makes absolutely no difference. I have attached the application to this post.. Tomislav |
July 10, 2012, 16:53 |
#8 | |
Edward Leonard
Rep Power: 13 |
As a final question about it, I do need to ask: does the order in which the distances are listed (from the cell center) follow the convention labeled in the OF manual? |
July 10, 2012, 16:57 |
#9 | |
Tomislav Maric
Rep Power: 21 |
Long answer: Well, this will get you the distance to the owner of the face. You still need to address the neighbour (you can safely put it in the same loop and separate the patchFace-owner distance in the loop over boundary faces), and for the patches that are coupled, you will need to do some communication. You may end up with two surfaceScalarFields this way, or a List<Pair<scalar,scalar>>. Btw, what are you using this for? |
July 11, 2012, 09:09 |
#10 | |
Edward Leonard
Rep Power: 13 |
cell center vector (x,y,z) cell center-to-face for all 6 faces (the renderer can only handle hex, simplifying life on this end), and I must know which number represents which face So, in sum, for each FV element, I need 9 inputs to reconstruct the geometry of the simulation. Which brings me to: I understand (slightly) what you mean about needing to worry about the neighbour cells as well as the owners, but how will I be able to tell (in the list) which cell a face belongs to, and is there a standard fashion in which the owner/neighbour is decided? |
July 12, 2012, 03:41 |
#11 | |
Tomislav Maric
Rep Power: 21 |
If I may just suggest, next time explain the actual task, this will save time ... If I (finally) understood you right, you need a cell centre vector written down in a file and next to it, 6 distances (scalars) from 6 different faces. In what order do you need those distances written? This is a structured mesh format, right? Do you need distance between the East West North South face, or something similar? |
July 12, 2012, 11:30 |
#12 | |
Edward Leonard
Rep Power: 13 |
You've hit the nail on the head at this point, it sounds like. This is a structured mesh, and as far as order goes, if we use the cell center as the reference: -x,-y,-z,+x,+y,+z But if they don't come out of OF in that order, that's fine, I have to convert everything to binary anyway |
July 12, 2012, 14:22 |
#13 | |
Tomislav Maric
Rep Power: 21 |
Okay, so basically, you have to re-create this connectivity for the whole mesh, since OF mesh has no idea about the axis alignment. So, here's a try: Code:
const cellList& cells = mesh.cells(); const surfaceVectorField& Cf = mesh.Cf(); const volVectorField& C = mesh.C(); vectorField basis(3); basis[0] = vector(1,0,0); basis[1] = vector(0,1,0); basis[2] = vector(0,0,1); List<List<scalar> > centreFaceDists (cells.size()); forAll (cells, I) { const cell& c = cells[I]; scalarField distances(c.size()); forAll (c, J) { const vector& cf = Cf[c[J]]; vector local = cf - C[I]; forAll (basis, K) { scalar dist = basis[K] & local; if (dist < 0) { distances[K] = dist; // The other projections will be 0. break; } else if (dist > 0) { distances[K + 3] = dist; // The other projections will be 0. break; } } } centreFaceDists[I] = distances; } //Info << centreFaceDists << endl; forAll (centreFaceDists, I) { Info << C[I].x() << " " << C[I].y() << " " << C[I].z() << " " << centreFaceDists[I][0] << " " << centreFaceDists[I][1] << " " << centreFaceDists[I][2] << " " << centreFaceDists[I][3] << " " << centreFaceDists[I][4] << " " << centreFaceDists[I][5] << endl; } |
July 12, 2012, 15:07 |
#14 | |
Edward Leonard
Rep Power: 13 |
Now, the mesh I'm using for test is structured and regular; each cell should be a rectangular prism, and checkMesh reports my smallest volume to be about . So, when I see the following for the center-to-face distance in a few cases scattered throughout the output: Code:
132.431 -1.10069 8.64881 -0.1 -2.22045e-16 -0.10119 5.68434e-14 0.100694 0.10119 132.631 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 0.100694 0.10119 132.831 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 0.100694 0.10119 133.031 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 0.100694 0.10119 133.231 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 0.100694 0.10119 133.431 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 0.100694 0.10119 133.631 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 0.100694 0.10119 133.831 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 0.100694 0.10119 134.031 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 2.22045e-16 0.10119 134.231 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 2.22045e-16 0.10119 134.431 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 2.22045e-16 0.10119 134.631 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 2.22045e-16 0.10119 134.831 -1.10069 8.64881 -0.1 -0.100694 -0.10119 2.84217e-14 0.100694 0.10119 135.031 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 0.100694 0.10119 135.231 -1.10069 8.64881 -0.1 -0.100694 -0.10119 0.1 0.100694 0.10119 Thoughts? |
July 17, 2012, 05:04 |
#15 |
Tomislav Maric
Rep Power: 21 |
@iamed:
I'm not sure why this happens, I've tried it on simple box hex meshes and it seems to be working without a problem. Anyway: you have a starting point now, time to do some debugging. |
October 10, 2012, 06:09 |
#16 |
Bill
Rep Power: 14 |
I see this has been largely dealt with, but just in case anyone else is struggling...
Tomislav's code compiles in 2.0.x, using writeCellCentres as a template, if (and only if) I add Code:
#include "fvCFD.h" |
May 27, 2022, 03:08 |
#17 |
hari charan
Rep Power: 4 |
Hi maric,
I added a subroutine that calculates cell center to center distance in x direction simliar to yours. But I am not getting the correct outPut. When I run a test case on 1D it is running fine. But for 2D its not working properly. Can you tell what's wrong in my code. I already posted it , I am attaching the link of my post here :capturing cell centers Thanks in advance |
Access cell face center / cell vertices | lichmaster | OpenFOAM Programming & Development | 7 | May 31, 2014 02:31 |
Hydrostatic Pressure and Gravity | miliante | OpenFOAM Running, Solving & CFD | 132 | October 7, 2012 22:50 |
How to calculate the cell area | Le | FLUENT | 0 | February 18, 2007 22:15 |
Cell face values computation un unstructured grids | Sergio Rossi | Main CFD Forum | 2 | May 28, 2006 10:04 |
calculate cell volume, center...? | Paul | Main CFD Forum | 5 | June 21, 2003 12:55 |
