Home > Forums > OpenFOAM Programming & Development
OpenFOAM basic integration
Like Tree1Likes
  • 1 Post By manju819
Old   April 3, 2014, 15:33
Default OpenFOAM basic integration
maybee is on a distinguished road
does OpenFOAM provide basic integral methods?
If I provide a mathematical function and the lower and upper limits of integration is there a OpenFOAM method to calculate the integral or do I have to use third party code?
greetings
maybee
maybee is offline   Reply With Quote
Old   April 9, 2014, 00:06
Dongyue Li
sharonyue is on a distinguished road
Check this out:can OpenFOAM calculate definite integral?
By Christian Butcher's hint, I am gonna try Remberg method. You can find Remberg's code somewhere else.
Best,
sharonyue is offline   Reply With Quote
Old   April 9, 2014, 05:02
hi,
thx, but I ve already used another library for basic numerical integration. I am not sure if I am allowed link it here (?).
Old   April 10, 2014, 09:21
Default Hi Maybee
Manjunath Reddy
manju819 is on a distinguished road
Its availble in OpenFOAM no need of third party soft
In the "/opt/openfoam222/applications/test/dataEntry" in the dataEntry.C you can find about the integration with the upper and lower limits. You can make that dataEntry.C by copying it to run folder.
Regards,
Manjunath
manju819 is offline   Reply With Quote
Old   April 10, 2014, 20:15
Dongyue Li
Regards,
Manjunath
Thanks bro, This Test-DataEntry.C can calculate integration. But when I run this Test-DateEntry.C it failed. So I just make it very simple:
#include "fvCFD.H"
#include "DataEntry.H"
#include "IOdictionary.H"
int main(int argc, char *argv[])
#   include "setRootCase.H"
#   include "createTime.H"
#   include "createMesh.H"
    IOdictionary dataEntryProperties
        IOobject
            "dataEntryProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    autoPtr<DataEntry<scalar> > dataEntry
        DataEntry<scalar>::New
            "dataEntry",
            dataEntryProperties
    scalar x0 = readScalar(dataEntryProperties.lookup("x0"));
    scalar x1 = readScalar(dataEntryProperties.lookup("x1"));
    Info<< "Integration" << nl
        << "    int(f(x)) lim(x0->x1) = " << dataEntry().integrate(x0, x1) << nl
        << endl;
    return 0;
While right now Im confused that where can I input my f(x), do you know? Thanks.
Old   April 10, 2014, 23:59
Default Hi sharonyue
Manjunath Reddy
Firstly it works like if we give x and y data, it interpolates linearly(default) or it uses cubic spline. So then by giving lower limit and upper limit it integrates over the limits and gives the data. This is how it works kk
Now coming to dataEntry....
you can see in dataEntryProperties
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dataEntryProperties;
x0 0.5;//lower limit
x1 1;//Upper limit
dataEntry table (
(0 0)//(x1,y1) point
(10 1));(x2,y2) point
dataEntry().integrate(x0, x1) //This is area under the region
Iterpolates this data and gives the stright line and on integration gives area under the region....
Post your error i will look into that....
Regards
Manjunath
sharonyue likes this.
Thread Tools
Trackbacks are On
Basic Of MovingMesh - OpenFoam! ali jafari OpenFOAM Native Meshers: blockMesh 0 December 20, 2012 05:31
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 09:07
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 16:39
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
