May 10, 2013, 07:48 |
flow solver won't recognize custom library
Håkon Bartnes Line
Rep Power: 14 |
Hi everyone,
I've written a modified version of the SpalartAllmarasIDDES model, named "SpalartAllmarasBasicIDDES", and I'm having some problems getting it to run. The code compiles just fine, and creates a custom library called "libMyIDDESModels.so". When I try to run a case with it, however, I get the following error message, indicating that the solver could not read my library: Code:
-> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /home/hakonbar/OpenFOAM/hakonbar-2.2.0/platforms/linux64GccDPOpt/lib/libMyIDDESModels.so: undefined symbol: _ZTIN4Foam14incompressible9LESModels20SpalartAllmarasBasicE --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libMyIDDESModels.so" It's odd that the RANS version worked, and not the IDDES version. On the other hand, the latter includes two custom objects that talk together, so maybe that adds some complexities that need to be accounted for when compiling? Here are the contents of the "options" file in my "Make" directory: Code:
EXE_INC = \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/LES/lnInclude \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude -I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude LIB_LIBS = \ -lincompressibleTurbulenceModel \ -lLESdeltas \ -lfiniteVolume \ -lmeshTools Code:
SpalartAllmarasBasic/SpalartAllmarasBasic.C SpalartAllmarasBasicIDDES/SpalartAllmarasBasicIDDES.C LIB = $(FOAM_USER_LIBBIN)/libMyIDDESModels Any suggestions from you would be greatly appreciated, dear foamers =) best regards, Håkon |
November 8, 2013, 06:55 |
Srivathsan N
Rep Power: 13 |
Dear Hakon,
I have the same problem as you do. But I feel the EXE_INC misses a ' \ ' (backslash) in the penultimate line. That might've lead to your error.
Regards, Srivaths |
April 7, 2014, 08:09 |
Philipp
Rep Power: 26 |
Hakon, I am facing exactly the same problem: simpleFoam works for my custom RANS model, but decomposePar doesnt. Did you solve the problem?
Philipp. EDIT: I found the solution here: http://www.cfd-online.com/Forums/ope...les-model.html Additionally to the "options" file of kOmegaSST I had to add an " -lincompressibleRASModels \". Now it works LIB_LIBS = \ -lincompressibleTurbulenceModel \ -lincompressibleRASModels \ -lfiniteVolume \ -lmeshTools
The skeleton ran out of shampoo in the shower. |
Display Modes | |
Error due to Unstructured Mesh with custom solver | fredo490 | OpenFOAM Running, Solving & CFD | 2 | March 6, 2015 02:46 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Suitable solver for Air/Air flow with different temperatures | cjm | OpenFOAM | 1 | January 20, 2011 04:17 |
Troubleshooting Unsteady Incompressible Flow Solver | dandalf | Main CFD Forum | 0 | November 15, 2010 10:55 |
