-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Add an inverse field into laplacianFoam (http://www.cfd-online.com/Forums/openfoam-programming-development/132992-add-inverse-field-into-laplacianfoam.html)
sharonyue April 8, 2014 21:16
2 Attachment(s)
Hi guys,
This solver is just for validation. I add this into laplacianFoam:
createField:
volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
    volScalarField TTT
        IOobject
            "TTT",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        scalar(1)/T,
        T.boundaryField().types()
    volScalarField TT
        IOobject
            "TT",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        scalar(1)/TTT,
solver:
solve
                fvm::ddt(TT) - fvm::laplacian(DT, TT)
I mean, I think TT is the same with T. So I expect that I get the same result of TT with T. But this two is not the same. See the picture:
Actually Im wondering if I can solve this equation(Regard this 1/exp(t) as a volScalarField), and get the field of T
\frac{{\partial \left( {{\rho _d}\frac{1}{{\exp \left( T \right)}}} \right)}}{{\partial t}} + \nabla  \cdot \left( {{\rho _d}{u_d}\frac{1}{{\exp \left( T \right)}}} \right) = .......
sharonyue April 13, 2014 21:23
Any ideas?
sharonyue April 14, 2014 23:26
Solved,
After this equation is solved. I have to rewrite this TT to write. Otherwise the solver will not wirte this TT. Then TT is the real T.
epi_c April 15, 2014 00:36
Originally Posted by sharonyue (Post 486153)
Solved,
I can't get what you said.
sharonyue April 15, 2014 03:24
Sorry, check it out:
    Info<< "Reading field T\n" << endl;
    volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
        mesh
    volScalarField TI
        IOobject
            "TI",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        scalar(1)/T,
while (simple.correctNonOrthogonal())
            solve
                fvm::ddt(TI) - fvm::laplacian(DT, TI)
T = scalar(1)/TI;
 runTime.write()
