Assigning boundary value to every cell above it
Old   April 11, 2014, 15:33
Default Assigning boundary value to every cell above it
CHARLES
CHARLES is on a distinguished road
I'm stuck on something that seems rather trivial so I was hoping maybe somebody could give me a hand...
I would like to assign the value of friction velocity, utau, AT A WALL (for a given x-coordinate) to every cell above it (i.e: utau(x=i,y=allCells)=utau(x=i,y=0)).
My problem is that when I compute utau, I only get values at the boundaries, while the rest of the volScalarField is left as its initialized value (0). When I look at the output in the time step directories and ParaView, I can see that there are utau values for solid boundaries only, not for cell centers... which makes sense given how I defined utau (see below).
The question:
How can I tell OpenFOAM to assign the value of utau (at the wall) to all of the cells above it at each x-location?
Reason for doing this:
I am adding a scalar term to the dissipation equation that has utau in it. Since the solver loops through each cell, I need to assign the value of utau (at the wall) to each cell center in the corresponding column.
I'm assuming that utau will vary as you move in the x-direction since dUdy will be different.
Below are the definitions of utau and my implementation in OpenFOAM. I understand that the code below only gives me utau at the boundaries, I just don't know how to tell it to assign that value to all cells above.
I aplogize, for my coding skills aren't the best
utau = sqrt(tau_wall/rho) = sqrt(mu * dUdy / rho) = sqrt( nu * dUdy)
in OpenFOAM:
forAll(utau.boundaryField(), patchi)
        utau.boundaryField()[patchi]=
        sqrt
                            nu()*mag(U_.boundaryField()[patchi].snGrad())
Thanks ahead of time!
CHARLES is offline   Reply With Quote
Old   April 11, 2014, 22:55
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You can access the cells next to a patch using faceCells().
forAll(mesh.boundary()[patchI], faceI) //patchI: label of your target patch
    utau[mesh.boundary()[patchI].faceCells()[faceI]] = ...
Hope this helps,
Fumiya
My slides about OpenFOAM (http://www.slideshare.net/fumiyanozaki96)
fumiya is offline   Reply With Quote
Old   April 15, 2014, 12:59
CHARLES
Hi Fumiya,
Thank you for replying!
I'm still a little confused about what you are suggesting... What do you mean by 'target patch'?
Also, how would I assign a single value (utauw at the boundary) to every cell above it so that OpenFOAM doesn't complain about assigning a Foam::Field<double> to a 'double' ?
I have looked over some existing code and I'm implementing the following:
const fvPatchList& patcha = mesh_.boundary();
    forAll(patcha, patchi)
        const fvPatch& currPatch = patcha[patchi];
        if (isType<wallFvPatch>(currPatch))
            utauw.boundaryField()[patchi] = sqrt
            forAll(currPatch, facei)
                label faceCelli = currPatch.faceCells()[facei];
                // Assign utau from boundary to face values in internal field
                utau[faceCelli] = utauw[patchi];
The code above calculates utauw (at the wall) correctly, but it does not assign its value to utau (cells above boundary). As a matter of fact, utau still holds the value at which it was initialized at.
I need to somehow store the value produced by
at the boundary faces.
Old   April 15, 2014, 17:36
fumiya's Avatar
Fumiya Nozaki
Hi CHARLES,
You might want to try
utau[faceCelli] = utauw.boundaryField()[patchi][facei];
//RHS: utauw value at each boundary face(label: facei) on the boundary(label: patchi)
instead of
in your code.
Hope this helps,
Fumiya
[Personal]
Old   April 15, 2014, 23:19
Question
CHARLES
Fumiya,
I'm sorry but after re-reading my post, I realized that I wasn't very clear.
What you suggested allowed the script to compile and run! It also gave the results you had expected: the utauw value (at the boundary) is being assigned to utau (at the cell centers in contact with the boundary). utau is now a nonuniform list, which also solved part of the problem that I was having before.
However, what I intended to do was to copy the value of utauw (from the boundary) to ALL cell centers above it, not just the boundary cell centers.
I tried to write another forAll loop that would loop through all of utau, which would compile but I get a segmentation fault in the log file on the first iteration. I think I'm trying to assign a boundary's value to a single cell, which may be the cause of the problem.
label PatchID = mesh_.boundaryMesh().findPatchID("plate");
label FaceID = 0;
forAll(utau, celli)
    utau[celli] = utauw.boundaryField()[PatchID][FaceID];
Starting time loop
Time = 1e-05
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 1.36617e-07, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 1.36614e-07, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.999805, Final residual = 9.67079e-07, No Iterations 531
time step continuity errors : sum local = 3.21009e-14, global = 1.1476e-17, cumulative = 1.1476e-17
[0] #0  Foam::error::printStack(Foam::Ostream&) in "/home/sebastian/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigSegv::sigHandler(int) in "/home/sebastian/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3  Foam::incompressible::RASModels::SPLRRIP::correct() in "/home/sebastian/OpenFOAM/sebastian-2.2.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleRASModels.so"
[0] #4
[0]  in "/home/sebastian/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #6
[navier1:20000] *** Process received signal ***
[navier1:20000] Signal: Segmentation fault (11)
[navier1:20000] Signal code:  (-6)
[navier1:20000] Failing at address: 0x3eb00004e20
[navier1:20000] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f4ee6cbd4a0]
[navier1:20000] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f4ee6cbd425]
[navier1:20000] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f4ee6cbd4a0]
[navier1:20000] [ 3] /home/sebastian/OpenFOAM/sebastian-2.2.0/platforms/linux64GccDPOpt/lib/libmyIncompressibleRASModels.so(_ZN4Foam14incompressible9RASModels7SPLRRIP7correctEv+0x667) [0x7f4edf6d1b97]
[navier1:20000] [ 4] simpleFoam() [0x419c45]
[navier1:20000] [ 5] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f4ee6ca876d]
[navier1:20000] [ 6] simpleFoam() [0x41b49d]
[navier1:20000] *** End of error message ***
btw, thank you for explaining the boundary field indexing!
Old   April 18, 2014, 17:30
CHARLES
I believe I may have solved the segmentation problem...
However, I still have a few questions about the following part of the program:
 forAll(Boundaries, patchi) //loops through boundaries
            sqrt
1. Is the gradient, snGrad(), being calculated for the patch as a whole? or is it being done on a face-by-face basis?
The reason I ask is because the value of utauw that is output to the time directory doesn't change (for a flat plate) but one would expect that the gradient of the velocity would be a function of the streamwise-distance along the plate.
When I look at utauw for a different geometry, like a 2D bump, it varies in the time directory output.
2. Why is the following not correct
        utau2[faceCelli] =             sqrt
                            nu()*mag(U_.boundaryField()[patchi][facei].snGrad())
Error:
SPLRRIP.C: In member function ‘virtual void Foam::incompressible::RASModels::SPLRRIP::correct()’:
SPLRRIP.C:526:72: error: ‘const class Foam::Vector<double>’ has no member named ‘snGrad’
make: *** [Make/linux64GccDPOpt/SPLRRIP.o] Error 1
But it will work if this is done instead:
            sqrt
                label faceCelli = currPatch.faceCells()[facei]; //indexed face in current patch
                // Assign utau[on indexed cell face] value from utauw[on boundary][at each boundary face]
Solution Diverging with Trimmer Mesh rietuk STAR-CCM+ 8 February 27, 2013 04:50
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 01:54
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
How to identify a boundary cell? pctopcool FLUENT 1 August 23, 2010 04:31
