Home > Forums > OpenFOAM Programming & Development
Question about implement IQN-ILS algorithm in icoFsiElasticNonLinULSolidFoam
Old   April 15, 2014, 09:02
Question Question about implement IQN-ILS algorithm in icoFsiElasticNonLinULSolidFoam
Jinbin Ge
gejiabin is on a distinguished road
icoFsiElasticNonLinULSolidFoam is available in foam-extend-3.0.
After reading the papar“performance of a new partitioned procedure versus a monolithic in fluid-structure interaction”.
http://web.mit.edu/kjb/www/Principal...nteraction.pdf
I try to implement IQN-ILS algorithm in icoFsiElasticNonLinULSolidFoam according to paper.Blow is my code.
1.Add two line into createInterfaceFields.H
SLList<scalarRectangularMatrix> deltaInput;
SLList<scalarRectangularMatrix> deltaOutput;
2.The main code is in setInterfaceDisplacement.H
  else if (couplingScheme == "IQN-ILS")
     Info<< "IQN-ILS iteration: "<<endl;
     //if(outerCorr>20)
     // deltaInput.removeHead();
     // deltaOutput.removeHead();
     int numColumn(0);
     int dim=2;//3
     int numDegreeOfFreedom( dim*mesh.boundaryMesh()[fluidPatchID].nPoints() );
     scalarRectangularMatrix vMatrix(numDegreeOfFreedom,deltaInput.size()+1,0);
     scalarRectangularMatrix wMatrix(numDegreeOfFreedom,deltaInput.size()+1,0);
     scalarRectangularMatrix vVector(numDegreeOfFreedom,1,0);
     scalarRectangularMatrix temp(numDegreeOfFreedom,1,0);
     //1.Assemble vMatrix
     for(int id=0;id<numDegreeOfFreedom;id=id+dim)
      for(int i=0;i<dim;i++)
       temp[id+i][0]=(fsiResidualOld[id/dim][i]-fsiResidual[id/dim][i]);
     forAllIter(SLList<scalarRectangularMatrix>,deltaInput,iter)
       (*iter)=(*iter)+temp;
       for(int i=0;i<numDegreeOfFreedom;i++)
        vMatrix[i][numColumn]=(*iter)[i][0];
       numColumn+=1;
     deltaInput.append(temp);
      vMatrix[i][numColumn]=temp[i][0];
     //2.Assemble vVecotr
       vVector[id+i][0]=-fsiResidual[id/dim][i];
     //3.Assemble wMatrix
     numColumn=0;
       temp[id+i][0]=(fluidPatchPointsDisplOld[id/dim][i]-fluidPatchPointsDispl[id/dim][i]);
     forAllIter(SLList<scalarRectangularMatrix>,deltaOutput,iter)
        wMatrix[i][numColumn]=(*iter)[i][0];
       numColumn+=1;
     deltaOutput.append(temp);
      wMatrix[i][numColumn]=temp[i][0];
       //4.Update fluidPatchPointsDispl
     fluidPatchPointsDisplOld = fluidPatchPointsDispl;
     multiply(temp,wMatrix,SVDinv(vMatrix),vVector);
       fluidPatchPointsDispl[id/dim][i]+=(temp[id+i][0]-vVector[id+i][0]) ;
      Info<<"end:"<<endl;
But the new solver can't convergence for the benchmark proposed in the Hron & Turek paper.
But I change the code line from:fluidPatchPointsDispl[id/dim][i]+=(temp[id+i][0]-vVector[id+i][0]);
to:fluidPatchPointsDispl[id/dim][i]+=(temp[id+i][0]);
Things get a little better,but it still can't meet convergence criteria.
[IMG]http://b170.photo.store.qq.com/psb?/V11dkwCX1wKa4a/GjfsQ*slhvGFcYuS46SR.znc5g*L*kXjlU4qiJ.g7og!/b/dEguYGVAKAAA&bo=1wKAAgAAAAADAHI![/IMG]
gejiabin is offline   Reply With Quote
Old   June 28, 2015, 08:05
Stephanie
stephie is on a distinguished road
Hey,
did you find a solution?
I work with this benchmark too and I am really interessted in implementing the new algorithm in the HronTurekFsi Case.
I would be very grateful for your help.
Best regards,
Stephie
stephie is offline   Reply With Quote
Old   June 28, 2015, 12:00
Dongyue Li
sharonyue is on a distinguished road
Sorry,
But actually its quite excited to see "image can not be cited from QQ without permission", um. In my primary language.
Im the translator of OpenFOAM User Guide Chinese Edition! But always newbie on CFD.
Never too old to learn CFD. Worship these CFD experts.
sharonyue is offline   Reply With Quote
Old   July 1, 2015, 05:44
Johan Lorentzon
pi06jl6 will become famous soon enough
I am currently working with this case, Stephie, keep us posted about your findings! Are you using the FSI-PFS-2A setting? I am using M. Breuers data as reference, what data are you using? Could you describe your case setting? Best Regards /Johan
FYI: IQN-ILS is implemented in icoFsiElasticNonLinULSolidFoam.
pi06jl6 is offline   Reply With Quote
elasticnonlinulsolidfoam, icofsi, iqn-ils
Thread Tools
Trackbacks are On
On the pimpleFoam solution algorithm vkrastev OpenFOAM 1 February 1, 2011 09:25
Question on Pressure and Velocity Fields with SIMPLE algorithm Phiper Main CFD Forum 0 November 18, 2010 19:29
Question regarding the F2F particle tracking algorithm implementation. andrewryan OpenFOAM 2 October 22, 2009 01:55
Question to SIMPLE algorithm by Patankar's book. Rafal Main CFD Forum 2 December 21, 2005 04:48
SIMPLER Algorithm question Erik Main CFD Forum 1 May 23, 2004 03:57
