Adding temperature to pisoFoam
Like Tree10Likes
  • 2 Post By Red Devil
  • 1 Post By Red Devil
  • 3 Post By alexeym
  • 1 Post By alexeym
  • 2 Post By alexeym
  • 1 Post By jherb
Old   April 17, 2014, 14:31
Default Adding temperature to pisoFoam
RD
Red Devil is on a distinguished road
Hi All,
If someone has successfully added temperature to pisoFoam solver, I request you to share your Solver folder (one with *.C and createFields.H files) and any one of your case folders (with '0', 'Constant' and 'System' folders) which you have successfully run.
I have successfully added temperature to icoFoam using the instructions given here:
HTML Code:
http://openfoamwiki.net/index.php/How_to_add_temperature_to_icoFoam
Using the same procedure, I added temperature to pisoFoam also and the solver runs fine. I just want to confirm the correctness of my solver. Please provide some help.
Thanks in advance.
ashvinc9 and y_jiang like this.
Red Devil is offline   Reply With Quote
Old   April 17, 2014, 23:41
Dongyue Li
sharonyue is on a distinguished road
Createfields
    Info<< "Reading field p\n" << endl;
    volScalarField p
        IOobject
            "p",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
    Info<< "Reading field U\n" << endl;
    volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
        mesh
Info<< "Reading field T\n" <<endl;
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
mesh
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::NO_WRITE
dimensionedScalar DT
transportProperties.lookup("DT")
#   include "createPhi.H"
    label pRefCell = 0;
    scalar pRefValue = 0.0;
    setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
    singlePhaseTransportModel laminarTransport(U, phi);
    autoPtr<incompressible::turbulenceModel> turbulence
        incompressible::turbulenceModel::New(U, phi, laminarTransport)
solver:
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "readPISOControls.H"
        #include "CourantNo.H"
        // Pressure-velocity PISO corrector
            // Momentum predictor
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              + turbulence->divDevReff(U)
            UEqn.relax();
            if (momentumPredictor)
                solve(UEqn == -fvc::grad(p));
            // --- PISO loop
            for (int corr=0; corr<nCorr; corr++)
                volScalarField rAU(1.0/UEqn.A());
                volVectorField HbyA("HbyA", U);
                HbyA = rAU*UEqn.H();
                surfaceScalarField phiHbyA
                    "phiHbyA",
                    (fvc::interpolate(HbyA) & mesh.Sf())
                  + fvc::ddtPhiCorr(rAU, U, phi)
                adjustPhi(phiHbyA, U, p);
                // Non-orthogonal pressure corrector loop
                for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
                    // Pressure corrector
                    fvScalarMatrix pEqn
                        fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                    pEqn.setReference(pRefCell, pRefValue);
                    if
                        corr == nCorr-1
                     && nonOrth == nNonOrthCorr
                        pEqn.solve(mesh.solver("pFinal"));
                    else
                        pEqn.solve();
                    if (nonOrth == nNonOrthCorr)
                        phi = phiHbyA - pEqn.flux();
                #include "continuityErrs.H"
                U = HbyA - rAU*fvc::grad(p);
                U.correctBoundaryConditions();
		fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
TEqn.solve();
        turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
Is this right?
sharonyue is offline   Reply With Quote
Old   April 18, 2014, 14:31
Default Adding Temperature to pisoFoam
RD
Thanks for posting your files sharonyue.
I have one change in my solver file. I kept the TEqn outside the piso loop. Which one is correct?
Also, I've seen many people using kappat while adding temperature to pisoFoam. Please help me to understand kappat and it's significance
Old   April 18, 2014, 15:48
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
would you like to reimplement buoyantBoussinesqPimpleFoam (with thermal expansion coefficient equal to zero, as you did not modify momentum equations)? In that solver temperature equation is solver just after velocity equation.
UPD. kappat is turbulent heat conductivity. If you're planning to simulate heat transfer in turbulent flow, then you should account for it, otherwise, you can forget about it.
alexeym is offline   Reply With Quote
Old   April 18, 2014, 21:05
Dongyue Li
Originally Posted by alexeym View Post
Absolutely rite! I once made a comparison with this TpisoFoam and buoyantBoussinesqPimpleFoam with CFX, the latter is more accurate. Maybe we should consider this kappat into a turbulent solver.
And whether to put it in or out piso loop(after turbulence correction). I just made a comparison too. It is totally the same without any difference... See the picture. So I think put it out of the loop is better to save more calculating time.
Regards,
Old   April 19, 2014, 01:15
RD
Thanks alexeym and sharonyue for your inputs.
I'm trying to create a turbulent solver to solve forced convection heat transfer problem. What all changes I have to make for that?
hkowalczyk likes this.
Old   April 19, 2014, 01:41
Alexey Matveichev
if you'd like to create this solver for the sake of creation of the solver, then you should also add buoyancy force to momentum equation.
If you'd like to have this solver for practical reasons (running simulations, obtaining results) then you can just use buoyantBousinesqPimpleFoam. And if you like it to behave like "pisoFoam with temperature and buoyancy" set number of outer correctors (nOuterCorrectors in PIMPLE dictionary) to 1.
Old   April 19, 2014, 01:53
RD
Hi alexeym,
I'm not considering buoyancy in my problem.
Old   April 19, 2014, 02:00
Alexey Matveichev
OK. Set beta (thermal expansion coefficient) to zero and there will be no buoyancy in buoyantBoussinesqPimpleFoam.
Or if you'd like to go with "your own" solver, here is how turbulent heat diffusivity is calculated:
    alphat = turbulence->nut()/Prt;
    alphat.correctBoundaryConditions();
    volScalarField alphaEff("alphaEff", turbulence->nu()/Pr + alphat);
then alphaEff is used in laplacian of temperature equation.
sharonyue, Red Devil and vcvedant like this.
Old   April 19, 2014, 02:05
RD
Thanks a lot alexeym. Will try that.
Old   April 19, 2014, 15:32
RD
Hi alexeym,
I've successfully added temperature to pisoFoam by following your inputs. Thanks a lot.
I've another question. I want to set a constant heat flux (q w/m2) boundary condition on a wall. I did it this way:
    wall
        type      fixedGradient;
        gradient      uniform 100;
where the uniform value of temperature gradient is calculated as q/k (k-thermal conductivity).
Is this correct?
Old   April 19, 2014, 16:11
Alexey Matveichev
no, it won't be correct, you need heat transfer coefficient (http://en.wikipedia.org/wiki/Heat_transfer_coefficient).
Old   April 20, 2014, 02:38
RD
Oh! Then how to implement this constant heat flux bc? I'm totally confused.
Old   April 20, 2014, 05:15
Alexey Matveichev
Well...
start with description of the problem, as "...forced convection heat transfer problem..." is not enough (you'd like to use q = hc*(T - Tinf) relation for calculation of heat flux, it OK, but to calculate that hc one needs to know more about problem).
Then
$ cd $FOAM_SRC
$ find . -iname '*wallHeat*'
this will give you possible starting points for implementation of your BC.
Red Devil likes this.
Old   April 20, 2014, 06:58
RD
Problem is flow of water through a square duct. At one wall of the duct, I want to give constant heat flux. Want to run both laminar and turbulent cases. For laminar case i'm using modified icoFoam and for turbulent, modified pisoFoam.
So I have to find h for my problem, then from q=h*(T-Tinf) I can get T.
Then the temperature bc is a uniform fixedValue? Is that the way?
Old   April 20, 2014, 12:28
Alexey Matveichev
If you just go with buoyantBoussinesqPimpleFoam (with beta equal zero cause you don't need buoyancy), you can avoid this zoo of solvers, as it is capable of simulating momentum and heat transfer in laminar and turbulent regimes.
Actually everything is described in the wikipedia article. But if you'd like to see the math...
1. You've got heat transfer from fluid into a wall and them heat transfer inside the wall. And three temperatures T_fluid, T_wall (temperature of a wall near the fluid interface), T_inf (temperature of the wall at the infinity). You'd like to estimate hc of the system, so you can write q = hc*(T_fluid - T_inf)
2. 1/hc = 1/hc_flud->wall + 1/hc_wall. As we have got fluid, we can assume ideal contact with the wall, so 1/hc_fluid->wall will be equal 0 (so T_wall = T_fluid).
3. Heat transfer coefficient inside the wall can be estimated as kappa_wall/L_wall, where kappa_wall is heat conductivity of the wall material, L_wall is the thickness of the wall.
And finally if your wall thickness is zero, then yes, BC should be fixed value with T_inf.
sharonyue and Red Devil like this.
Old   April 22, 2014, 17:50
Joachim Herb
jherb is on a distinguished road
I think you are looking for the turbulentHeatFluxTemperature boundary condition:
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H
jherb is offline   Reply With Quote
pisofoam, temperature.add
Adding temperature equation to porousSimpleFoam David_010 OpenFOAM Programming & Development 9 February 14, 2018 01:22
chtMultiRegionSimpleFoam: strange error samiam1000 OpenFOAM Running, Solving & CFD 26 December 29, 2015 22:14
Problems adding temperature to icoFoam sur4j OpenFOAM Programming & Development 8 January 11, 2015 01:14
pisoFoam LES turbulent model + temperature Byxon OpenFOAM Programming & Development 0 October 4, 2013 06:55
Adding Temperature in channelFoam dhruv OpenFOAM 10 May 5, 2012 05:40
