value of alpha1[celli] is not correct
Old   May 27, 2014, 12:32
Default value of alpha1[celli] is not correct
jaming
jaming is on a distinguished road
Hi Foamers,
I have a problem setting in the forAll() loop the right condition:
forAll(alpha1,celli)
if (alpha1[celli] > 1 )
Pout<<"alpha1= "<<alpha1[celli]<<endl;
I also get
alpha1= 1
in the results what I think is not logic.
So if someone has any idea I will be thankful
Yamine
jaming is offline   Reply With Quote
Old   May 27, 2014, 14:34
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo,
It is probably related to your write precision in your controlDict, e.g. if the write precision is 6, then 1.000000007 is written as 1.
You could test this by using the following code:
Pout << alpha1[celli] << tab << 1 - alpha1[celli] << endl;
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 27, 2014, 16:01
jaming
Many thanks for you quick replay,
but look for example hier:
forAll(alpha1, celli)
     if ( alpha1[celli] < scalar(1.))
         Pout<< "Alpha1=  "<<alpha1[celli]<< endl;
I get the flow:
PHP Code:
Alpha1=  0.0144193383
Alpha1
=  0.9575155878
Alpha1
=  1
Alpha1
=  0.1574193345
Alpha1
=  5.502415325e-11
Alpha1
=  5.162033835e-11
Alpha1
=  8.173407791e-13
The idea is to set some conditions with alpha1 but I found that alpha1[celli] didn't pass the wished value at all.
And like you can see unfortunately 1 is not filtered here
With kind regards,
Yamine
Old   May 27, 2014, 16:13
ngj
With your recent code, you turned around the inequality, and the value being 1, can actually be 0.9999999999, i.e. to me the code still does the rigth thing.
Kind regards,
Niels
Old   May 27, 2014, 16:36
jaming
Hi ngj
Many Thanks for your unpayable help.
Regards
Yamine
Is my Dynamic mesh setup correct? cfd seeker FLUENT 16 October 30, 2020 06:16
Evaporation due to Heat Transport using InterFoam (Correct Implementation?) ovie OpenFOAM 14 August 3, 2019 07:00
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Is there a way to find a correct "spacing"? Jordi P. Main CFD Forum 2 August 15, 2013 10:05
LES correct function luiz eduardo OpenFOAM Running, Solving & CFD 6 September 14, 2007 04:10
