How to input a list
Old   June 10, 2014, 09:05
Default How to input a list
otq
Christopher Hughes
otq is on a distinguished road
I am looking to create an equation of state library that uses tables instead of an equation to determine properties. I am pretty happy with the structure that I have; however, I cannot seem to get the syntax correct.
I am currently trying to enter a large set of 200 cell arrays into the main header file so that when I call the equation file (PerfectGasI.H for example) I don't have to load all the arrays, but will reference only the ones I need.
I have currently tried the following:
inline scalar cpa1[200] = ( # # # ....);
inline scalar cpa1[200] = ( #,#,#,....);
inline scalar cpa1[200] = { # # # ....};
inline scalar cpa1[200] = { #,#,#,....};
inline scalar cpa1[200] and then entering the values in the .C file.
I have also tried double without the inline to know avail.
After going through the errors, I'm pretty sure that the form inline scalar cpa1[200] = (# # # ...) is the closest to correct; however, I still get the following errors
expected ‘)’ before numeric constant
error: ISO C++ forbids initialization of member ‘cpa1’ [-fpermissive]
error: making ‘cpa1’ static [-fpermissive]
error: invalid in-class initialization of static data member of non-integral type ‘Foam::scalar [200] {aka double [200]}’
The array in question is reproduced below.
inline scalar cpa1[200] = (3.97 3.9726 3.9752 3.9778 3.9804 3.983 3.9856 3.9882 3.9908 3.9935 3.9961 3.9988 4.0014 4.0041 4.0068 4.0094 4.0121 4.0148 4.0175 4.0202 4.0229 4.0256 4.0283 4.0311 4.0338 4.0365 4.0393 4.0421 4.0448 4.0476 4.0504 4.0532 4.0559 4.0587 4.0616 4.0644 4.0672 4.07 4.0729 4.0757 4.0786 4.0814 4.0843 4.0872 4.09 4.0929 4.0958 4.0987 4.1016 4.1046 4.1075 4.1104 4.1134 4.1163 4.1193 4.1222 4.1252 4.1282 4.1312 4.1342 4.1372 4.1402 4.1432 4.1463 4.1493 4.1524 4.1554 4.1585 4.1616 4.1646 4.1677 4.1708 4.1739 4.1771 4.1802 4.1833 4.1865 4.1896 4.1928 4.1959 4.1991 4.2023 4.2055 4.2087 4.2119 4.2151 4.2184 4.2216 4.2249 4.2281 4.2314 4.2347 4.238 4.2413 4.2446 4.2479 4.2512 4.2545 4.2579 4.2612 4.2646 4.268 4.2714 4.2748 4.2782 4.2816 4.285 4.2884 4.2919 4.2953 4.2988 4.3023 4.3058 4.3093 4.3128 4.3163 4.3198 4.3233 4.3269 4.3305 4.334 4.3376 4.3412 4.3448 4.3484 4.352 4.3557 4.3593 4.363 4.3666 4.3703 4.374 4.3777 4.3814 4.3852 4.3889 4.3926 4.3964 4.4002 4.404 4.4077 4.4116 4.4154 4.4192 4.423 4.4269 4.4308 4.4346 4.4385 4.4424 4.4464 4.4503 4.4542 4.4582 4.4621 4.4661 4.4701 4.4741 4.4781 4.4822 4.4862 4.4903 4.4943 4.4984 4.5025 4.5066 4.5108 4.5149 4.519 4.5232 4.5274 4.5316 4.5358 4.54 4.5442 4.5485 4.5527 4.557 4.5613 4.5656 4.5699 4.5743 4.5786 4.583 4.5874 4.5918 4.5962 4.6006 4.605 4.6095 4.6139 4.6184 4.6229 4.6274 4.632 4.6365 4.6411 4.6457 4.6502 4.6549);
Should I initialize it as a vector (vector<double> cpa1(200); ) and then use cpa1.assign( # # # # ...)?
Any help will be greatly appreciated.
otq is offline   Reply With Quote
Old   June 10, 2014, 09:47
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
http://www.cplusplus.com/doc/tutorial/arrays/
Can you show the error you get when you've used
scalar cpa1[200] = { number1, number2, ... };
alexeym is offline   Reply With Quote
Old   June 10, 2014, 09:59
otq
Christopher Hughes
error: a brace-enclosed initializer is not allowed here before ‘{’ token
I am using OpenFOAM 2.1.1 if that helps at all.
adding static before scalar produces the following errors:
so that is a step in the right direction.
Old   June 10, 2014, 10:13
otq
Christopher Hughes
Fixed it. The issue was that the array has to be initialized in the class, but assigned a value outside of the class definition. Once this was done, the system compiled.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
