February 10, 2016, 11:25 |
trouble using meshTools
Rep Power: 15 |
Hello All,
I am trying to find the shared face between two given cells(who are neighbors), and i wanted to use the function getSharedFace() however, it does not compile and i have tried many different iterations. Does anyone know how to declare/use this function? Foam::label Foam::meshTools::getSharedFace ( const primitiveMesh& mesh, const label cell0I, const label cell1I ) is the function call in meshTools.C I have written it into the code as, label faceI = Foam::meshTools::getSharedFace(primMesh(), celli, n_celli); and this error comes out, error: ‘Foam::meshTools’ has not been declared, however i have included src/meshTools into the make directory, and when i try to add it into this file it gives the error for #include "meshTools/meshTools.H", /usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/src/meshTools/meshTools/meshTools.H:48: error: ‘namespace’ definition is not allowed here or for #include "meshTools.H" error: meshTools.H: No such file or directory however none of it seems to fix the problem, any thoughts? |
coding, meshtools.h, openfoam, openfoam 2.1.1 |
Trouble with sampleDict syntax for OpenFOAM 2.3.1 | rawdoggity | OpenFOAM Post-Processing | 1 | February 1, 2015 05:24 |
Trouble with big domain of study, | johnnyp | FLUENT | 3 | May 15, 2013 23:19 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
[GAMBIT] Trouble meshing complex VOF geometry | RPJones | ANSYS Meshing & Geometry | 2 | February 14, 2011 18:54 |
OpenFOAM-1.5-dev compilation: OSspecific trouble | gwierink | OpenFOAM Installation | 1 | September 24, 2009 09:35 |
