Heat Injection
Hi all,
I would like to model a subsonic turbulent flow of gas that will have a large amount of energy continuously injected into a particular volume using a laser. In particular, I want to observe the steady-state effects that this added heat has on the density (etc.) of the gas, so I can't just use a modified version of scalarTransportFoam. I feel like there ought to be a fairly strait-forward way of modifying one of the solvers (my initial thought is rhoSimpleFoam) to add heat within a pre-defined region. Any Ideas? Thanks, Pat |
Progress
I've made significant progress in my attempts. I have tried adding a constant value (which I called E) to the right or left hand side of the EEqn, so that I had:
fvScalarMatrix EEqn ( fvm::div(phi, he) + ( he.name() == "e" ? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho)) : fvc::div(phi, volScalarField("K", 0.5*magSqr(U))) ) - fvm::laplacian(turbulence->alphaEff(), he) == fvOptions(rho,he) + E ); or the same except with the E coming after the laplacian and before the == sign. I create the E field from a file with the values defined at all the cell centers to be either 0 or some value. With E either above or below the equal sign, for E = 1e5 and less, there is no difference to the solution. I have also tried commenting out EEqn.relax(), fvOptions.*(), thermo.correct(), and there has still been no change in the solution. What am I doing wrong? -- Pat Edit: The EEqn is from rhoSimpleFoam, and the energy file is correctly loaded with createFields. I've checked in paraview, and the data for E is correct. |
Are you sure that your energy values are correct? The unit of the internal energy e is J/m³. It's possible that your power density is higher than 1e5, but that's for you to decide.
Solved
You were right! Thanks. My values were just too low. I actually fixed this ages ago and forgot to reply.
