Accessing Mesh, Fields in Foam::sixDoFRigidBodyMotionRestraints::linearSprin g |
August 4, 2014, 01:22 |
kumar
Rep Power: 17 |
Hi Niels,
Thanks again for your reply. Just this last question I have . It would be great if you can give me some pointers ... Actually I am stuck with a library ( not waves2foam ), which cannot see the mesh or any other fields(U,p). I read in one of the posts that Istream can be used to access these fields. Are you aware of any code snippets that does this. Have a great week Best regards Kumar [Moderator note: moved from the old thread Waves2Foam Related Topics ] Last edited by wyldckat; October 8, 2018 at 10:09. Reason: see "Moderator note:" |
August 4, 2014, 03:40 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Kumar,
This thread is dedicated to waves2Foam, so I would recommend you to start a new thread. Furthermore do an effort in describing your problems in more detail, as it is otherwise impossible to help with your actual problem. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
August 4, 2014, 15:55 |
kumar
Rep Power: 17 |
Dear All,
Is there anyway to access the velocity fields and the mesh from inside the class: Foam::sixDoFRigidBodyMotionRestraints::linearSprin g The class is located here: OpenFOAM/OpenFOAM-2.1.0/src/postProcessing/functionObjects/forces/pointPatchFields/derived/sixDoFRigidBodyMotion/sixDoFRigidBodyMotionRestraint/linearSpring ( This method: http://www.cfd-online.com/Forums/ope...tml#post254591 , does not work for the linearSpring class) I came across this post, http://www.cfd-online.com/Forums/ope...tml#post266526 , which talks about using IFstream to access the mesh , field values. Can anyone comment a little more on this, perhaps give a code snippet as an example.. Thanks in advance Kumar |
August 4, 2014, 16:06 |
kumar
Rep Power: 17 |
Dear Niels,
My apologies for the misplaced posting and lack of info. As suggested by you, I have opened a new thread under programming&development. Here is a link if you choose to take a look, http://www.cfd-online.com/Forums/ope...tml#post504368 . I have to thank you again for your continued eagerness for keeping this wave2foam thread as active and informational as it possibly can be. Best regards Kumar |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 22:36 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Resetting all fields and mesh motion | wavemaster | OpenFOAM Programming & Development | 0 | May 21, 2012 13:00 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
