piston-type wave-maker by interDyMFoam
Old   November 5, 2013, 08:19
Default piston-type wave-maker by interDyMFoam
Jarvis
nbyjn is on a distinguished road
Dear FOAMers:
Glad to meet you! I want to make a piston-type wave-maker by interDyMFoam.
But I have two questions:
1.At the start-time, the piston(left boundary) moves rightward, so the water level should rise. But in fact, the water goes down! Do you have the same question?
2.interDyMFoam change the time-step automatically, so the solver runs slower and slower. It's so slow that it can't calculate for 0.1s in a whole night! Can anyone give me some advice?
Thank you very much!
nbyjn is offline   Reply With Quote
Old   November 5, 2013, 08:31
Jarvis
Hello everyone:
maybe I should some information for question 1:
If I set the wave height to be 0, which means the mesh is static, it can run well(for example, dam break)
But if the left boundary moves(to make wave),then it seems water doesn't move in the correct way.
Old   January 30, 2014, 17:01
Joachim Herb
jherb is on a distinguished road
Have you check that alpha1 = 1 means fluid and that gravity is pointing in the correct direction?
jherb is offline   Reply With Quote
Old   August 11, 2014, 06:24
Premal Sheth
premal is on a distinguished road
Send a message via Yahoo to premal Send a message via Skype™ to premal
Hi
can you please tell me how u gave wave height in interdymFoam?
Thanks,
premal is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
