difference between div(U) and div(phi)
Like Tree2Likes
  • 2 Post By Astrodan
Old   August 11, 2014, 04:43
Default difference between div(U) and div(phi)
fshak92 is on a distinguished road
Hi
Does anybody know why using each of div(U) or div(phi) provides same results?
I'm confused because the first one is volVectorField, and the latter is surfaceScalarField.
(Both of them are computed at the same time step and I'm using this in the Poisson eq.(Laplacian(p')=div(U)) )
Tnx
fshak92 is offline   Reply With Quote
Old   August 11, 2014, 05:02
Timm Severin
Astrodan is on a distinguished road
I don't know about the numerics, but as far as I understand a volField is stored in the center of the cell, while a surfaceField is stored on the faces. Thus both methods are just different ways of accessing the "same" data, and should ideally return the same results.
To convert them you can work with fvc::reconstruct (surface -> vol) or fvc::interpolate (vol -> surface).
A little attention should of course be paid where phi includes density (though I've seen it called rhoPhi for those cases), usually in compressible or multiphase problems.
fshak92 and adambarfi like this.
PhD Student at the Institute of Biochemical Engineering at TU München
Modelling of fluid dynamics in open photobioreactors.
System:
OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation
Astrodan is offline   Reply With Quote
Old   August 15, 2014, 08:53
Thank you very much for your response.
I've noticed that small differences can be seen in the result of those approaches.
Still I would like to know which one is completely correct if Poisson eq. should be solved? and why?
fvm::Laplacian(p') = fvc::div (U)
or
fvm::Laplacian(p') = fvc::div (phi)
Tnx in advance for any idea.
