Home > Forums > OpenFOAM Programming & Development
autoPtr in Openfoam code
Old   August 13, 2014, 08:38
Default autoPtr in Openfoam code
Hao Chen
hchen is on a distinguished road
I am pretty new to Openfoam and now trying to dig into the code.
If anybody can explain what is autoPtr, I met it several times but can not find any information about it. eg.
autoPtr<motionSolver> motionPtr_
Thanks!
Best regards
Hao
hchen is offline   Reply With Quote
Old   August 14, 2014, 08:48
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
Hi Hao,
an autoPtr<T> is a smart pointer, which is basically "nothing more" than a wrapper around C++ pointers and handles e.g. garbage collection in an automatic fashion. Resources are released automatically, when they are out of scope.
Good luck with the dynamic meshes
Jens
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   August 14, 2014, 09:25
Eric M. Tridas
eric.m.tridas is on a distinguished road
So if I understand correctly, using "autoPtr<T>" is preferable to using "new T()"?
eric.m.tridas is offline   Reply With Quote
Old   August 14, 2014, 09:40
Jens Höpken
autoPtr<T> myVar is preferable to T* myVar.
Old   August 14, 2014, 09:46
Eric M. Tridas
That makes sense. Thanks!
Old   August 14, 2014, 09:47
Jens Höpken
No problemo
Old   August 15, 2014, 04:46
Hao Chen
Hi Jens,
Thanks very much!
And one more question is that I can see in dynamic motion solver fv mesh, there are displacement laplacian and velocity laplacian, but I found one more mesh class called laplace...which equation does it solve? I can not find the source code of it...
Also waiting for your Openfoam book!
Hao
Originally Posted by jhoepken View Post
Hi Hao,
Jens
Old   August 15, 2014, 08:13
Jens Höpken
There are several types of motionSolvers:
  1. componentDisplacement
  2. componentVelocity
  3. displacement
  4. velocity
These are all virtual base classes for actual implementations motionSolvers. Look in $FOAM_SRC/fvMotionSolver/fvMotionSolvers (assuming you have the vanilla version of OpenFOAM).
For displacementLaplacianFvMotionSolver it solves Laplace equation:
void Foam::displacementLaplacianFvMotionSolver::solve()
    // The points have moved so before interpolation update
    // the motionSolver accordingly
    movePoints(fvMesh_.points());
    diffusivity().correct();
    pointDisplacement_.boundaryField().updateCoeffs();
    Foam::solve
        fvm::laplacian
            diffusivity().operator()(),
            cellDisplacement_,
            "laplacian(diffusivity,cellDisplacement)"
Old   August 15, 2014, 09:02
Hao Chen
Hi Jens,
I see, thank you!
Another thing is when I select some diffusivity models, say exponential or quadratic, the error shows that: attempt to read beyond EOF, but normally uniform diffusivity is OK...Do you have any idea about the reason?
Best regards
Hao
  3. displacement
  4. velocity
    Foam::solve
        fvm::laplacian
            cellDisplacement_,
Old   August 15, 2014, 09:41
Jens Höpken
Maybe you are missing a parameter? Or a semicolon? Look in the source code of the particular model you use, and check which parameters it requires.
Thread Tools
Trackbacks are On
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 13:25
How to calculate Reynolds stress tensor in OpenFOAM code. yzf1215 OpenFOAM Programming & Development 1 October 26, 2013 07:25
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
How to code integral of (DU/Dt - 2000 ) in openFoam erncyc OpenFOAM 5 September 13, 2012 06:33
OpenFOAM for subsurface flow, or coupling with a subsurface flow code? chljl OpenFOAM Running, Solving & CFD 0 February 14, 2012 20:38
