December 21, 2015, 13:29 |
buoyantBoussinesqSimpleFoam Compile error
S. Park
Rep Power: 11 |
Hi. Foamers.
Recently I've been looking for a solver which would be suitable for the HVAC system simulation, and I found buoyantBoussinesq solvers which are pimpleFoam type and simpleFoam type. For the first step of the programming, simply I compiled buoyantBoussinesqSimpleFoam, and for your information I'm using OpenFOAM 3.0.0. When I compile the solver, the error message is showed up said; ------------------------------------------------------------------------------------------------------------------------------- In file included from buoyantBoussinesqSimpleFoam.C:65:0: createFields.H: In function ‘int main(int, char**)’: createFields.H:80:59: error: no matching function for call to ‘Foam::RASModel<Foam::IncompressibleTurbulenceMode l<Foam::transportModel> >::New(Foam::volVectorField&, Foam::surfaceScalarField&, Foam::singlePhaseTransportModel&)’ incompressible::RASModel::New(U, phi, laminarTransport) ^ In file included from /opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude/RASModel.H:247:0, from /opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude/turbulentTransportModel.H:47, from buoyantBoussinesqSimpleFoam.C:50: /opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude/RASModel.C:115:1: note: candidate: static Foam::autoPtr<Foam::RASModel<BasicTurbulenceModel> > Foam::RASModel<BasicTurbulenceModel>::New(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&) [with BasicTurbulenceModel = Foam::IncompressibleTurbulenceModel<Foam::transpor tModel>; Foam::RASModel<BasicTurbulenceModel>::alphaField = Foam::geometricOneField; Foam::RASModel<BasicTurbulenceModel>::rhoField = Foam::geometricOneField; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>; Foam::RASModel<BasicTurbulenceModel>::transportMod el = Foam::transportModel] Foam::RASModel<BasicTurbulenceModel>::New ^ /opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude/RASModel.C:115:1: note: candidate expects 7 arguments, 3 provided /opt/openfoam30/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/buoyantBoussinesqSimpleFoam.o' failed make: *** [Make/linux64GccDPInt32Opt/buoyantBoussinesqSimpleFoam.o] Error 1 ------------------------------------------------------------------------------------------------------------------------------ I thought the most possible reason of the compile error is caused by the wrong function call with wrong source code and header files(the bolded and underlined message above), so I've checked the file root and the source code according to Make/option, but I got no idea to fix it. Is there anybody to give me some ideas to get this through? Any possible advices would be so helpful for me. Thanks. Best regards. S. Park |
buoyantboussinesq, compile |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
