October 20, 2014, 08:18 |
gammaCoeff in twoPhaseEulerFoam
Ramon
Rep Power: 12 |
Dear Foamers,
I would like to adjust the kineticTheoryModel.C file, more specifically the dissipation rate gammaCoeff. Currently the simplified equation 3.24 on page 50 of Van Wachem's thesis has been implemented. However, I would like to implement equation 3.23, where the divergence term of the solids velocity has not been neglected. Could I get some hints on how I could program this into the code properly? Currently I have this, but it is not working. Code:
// Dissipation (Eq. 3.24, p.50) /* volScalarField gammaCoeff ( 12.0*(1.0 - sqr(e_)) *max(sqr(alpha), residualAlpha_) *gs0*(1.0/da)*ThetaSqrt/sqrtPi );*/ // Added eqn. 3.23 from Van Wachem (RJWV) volScalarField gammaCoeff ( 3.0*(1.0 - sqr(e_))*max(sqr(alpha), residualAlpha_)*gs0 *((4.0/da)*(ThetaSqrt/sqrtPi) - fvm::div(U)) ); Ramon |
October 28, 2014, 05:56 |
Ramon
Rep Power: 12 |
Just for the sake of completion, it seems I have managed to tackle the problem myself. It was not that difficult after all, but hopefully it can aid someone in the future.
in kineticTheoryModel.C the following changes can be made: Code:
volScalarField divU = fvc::div(this->U_) Code:
volScalarField gammaCoeff ( 3.0*(1.0 - sqr(e_))*max(sqr(alpha), residualAlpha)*gs0 *((4.0/da)*(ThetaSqrt/sqrtPi) - divU) ); Kind regards, Ramon |
Sliding mesh for twoPhaseEulerFoam | Lapo | OpenFOAM Programming & Development | 4 | November 25, 2019 14:23 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 08:10 |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 10:48 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 16:24 |
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 | raagh77 | OpenFOAM Running, Solving & CFD | 0 | March 6, 2010 05:11 |
