October 30, 2014, 08:13 |
laminarNusselt utility
sajad
Rep Power: 11 |
I want to build NusseltCalcLaminar for Laminar flow.first I get wallHeatFluxLaminar of mr Tobias Holzmann. it's link is below
https://github.com/shor-ty/wallHeatFluxLaminar and I add it Nusselt formula: Code:
volScalarField NusseltNumber ( IOobject ( "NusseltNumber", runTime.timeName(), mesh ), mesh, dimensionedScalar("NusseltNumber", heatFlux.dimensions(), 0.0) ); forAll(NusseltNumber.boundaryField(), patchi) { NusseltNumber.boundaryField()[patchi] = length* patchHeatFlux[patchi]/((T_hot-T_initial)*k); } NusseltNumber.write(); but when I compile it I face with this error; sajad@sajad-pc:~/Desktop/nusseltCalcLaminar$ wmake SOURCE=nusseltCalcLaminar.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam210/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/nusseltCalcLaminar.o In file included from nusseltCalcLaminar.C:55: readRefValues.H: In function ‘int main(int, char**)’: readRefValues.H:13: error: conflicting declaration ‘Foam::scalar k’ createFields.H:17: error: ‘k’ has a previous declaration as ‘Foam::dimensionedScalar k’ nusseltCalcLaminar.C:112: error: no match for ‘operator/’ in ‘Foamerator*(const Foam::scalar&, const Foam::UList<T>&) [with Type = double](((const Foam::UList<double>&)(&((const Foam::fvsPatchField<double>*)((const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricBoundaryField*)patchHeatFlux)->Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricBoundaryField::<anonymous>.Foam::FieldField<Foam::fvsPatchField, double>::<anonymous>.Foam::PtrList<T>erator[] [with T = Foam::fvsPatchField<double>](patchi))->Foam::fvsPatchField<double>::<anonymous>.Foam::Field<double>::<anonymous>.Foam::List<double>::<anonymous>))) / Foamerator*(const Foam::dimensioned<double>&, const Foam::dimensioned<Type>&) [with Type = double](((const Foam::dimensioned<double>&)((const Foam::dimensioned<double>*)(& k))))’ /opt/openfoam210/src/OpenFOAM/lnInclude/fileName.H:194: note: candidates are: Foam::fileName Foamerator/(const Foam::string&, const Foam::string&) /opt/openfoam210/src/OpenFOAM/lnInclude/dimensionSet.H:275: note: Foam::dimensionSet Foamperator/(const Foam::dimensionSet&, const Foam::dimensionSet&) /opt/openfoam210/src/OpenFOAM/lnInclude/dimensionedScalar.H:56: note: Foam::dimensionedScalar Foamerator/(Foam::scalar, const Foam::dimensionedScalar&) /opt/openfoam210/src/OpenFOAM/lnInclude/scalarField.H:81: note: Foam::tmp<Foam::Field<double> > Foamperator/(const Foam::UList<double>&, const Foam::UList<double>&) /opt/openfoam210/src/OpenFOAM/lnInclude/scalarField.H:81: note: Foam::tmp<Foam::Field<double> > Foamperator/(const Foam::UList<double>&, const Foam::tmp<Foam::Field<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/scalarField.H:81: note: Foam::tmp<Foam::Field<double> > Foamperator/(const Foam::tmp<Foam::Field<double> >&, const Foam::UList<double>&) /opt/openfoam210/src/OpenFOAM/lnInclude/scalarField.H:81: note: Foam::tmp<Foam::Field<double> > Foamperator/(const Foam::tmp<Foam::Field<double> >&, const Foam::tmp<Foam::Field<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/scalarField.H:83: note: Foam::tmp<Foam::Field<double> > Foamperator/(const Foam::scalar&, const Foam::UList<double>&) /opt/openfoam210/src/OpenFOAM/lnInclude/scalarField.H:83: note: Foam::tmp<Foam::Field<double> > Foamperator/(const Foam::scalar&, const Foam::tmp<Foam::Field<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:58: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::UList<double>&, const Foam::UList<Foam::SphericalTensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:58: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::UList<double>&, const Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:58: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::tmp<Foam::Field<double> >&, const Foam::UList<Foam::SphericalTensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:58: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::tmp<Foam::Field<double> >&, const Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::scalar&, const Foam::UList<Foam::SphericalTensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::scalar&, const Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::UList<double>&, const Foam::sphericalTensor&) /opt/openfoam210/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double> > > Foamperator/(const Foam::tmp<Foam::Field<double> >&, const Foam::sphericalTensor&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:78: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamperator/(const Foam::UList<Foam::Vector<double> >&, const Foam::UList<Foam::Tensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:78: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamperator/(const Foam::UList<Foam::Vector<double> >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:78: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foam:perator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::UList<Foam::Tensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:78: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamperator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamperator/(const Foam::vector&, const Foam::UList<Foam::Tensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamperator/(const Foam::vector&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamperator/(const Foam::UList<Foam::Vector<double> >&, const Foam::tensor&) /opt/openfoam210/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::tensor&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:66: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::UList<Foam::Vector<double> >&, const Foam::UList<Foam:iagTensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:66: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::UList<Foam::Vector<double> >&, const Foam::tmp<Foam::Field<Foam:iagTensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:66: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::UList<Foam:iagTensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:66: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::tmp<Foam::Field<Foam:iagTensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:67: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::vector&, const Foam::UList<Foam:iagTensor<double> >&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:67: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::vector&, const Foam::tmp<Foam::Field<Foam:iagTensor<double> > >&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:67: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::UList<Foam::Vector<double> >&, const Foam::diagTnsor&) /opt/openfoam210/src/OpenFOAM/lnInclude/diagTensorField.H:67: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::diagTensor&) /opt/openfoam210/src/OpenFOAM/lnInclude/quaternionI.H:309: note: Foam::quaternion Foamerator/(const Foam::quaternion&, const Foam::quaternion&) /opt/openfoam210/src/OpenFOAM/lnInclude/quaternionI.H:331: note: Foam::quaternion Foamerator/(const Foam::quaternion&, Foam::scalar) /opt/openfoam210/src/OpenFOAM/lnInclude/septernionI.H:220: note: Foam::s epternion Foamerator/(const Foam::septernion&, const Foam::quaternion&) /opt/openfoam210/src/OpenFOAM/lnInclude/septernionI.H:244: note: Foam::s epternion Foamerator/(const Foam::septernion&, const Foam::septernion&) /opt/openfoam210/src/OpenFOAM/lnInclude/septernionI.H:266: note: Foam::s epternion Foamerator/(const Foam::s epternion&, Foam::scalar) make: *** [Make/linuxGccDPOpt/nusseltCalcLaminar.o] Error 1 Last edited by sajad6; November 1, 2014 at 15:14. |
October 24, 2015, 16:14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings sajad6,
I've had this post of yours on my to-do list almost a year and only today did I manage to take a look into this The solution is/was simple:
Bruno |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[mesh manipulation] mirrorMesh utility preserving regions | zfaraday | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2016 21:51 |
problem with sampling Utility in openFOAM 1.6 | carmir | OpenFOAM Post-Processing | 10 | February 26, 2014 02:00 |
How to compile a new utility | rudy | OpenFOAM | 4 | October 1, 2011 22:48 |
StreamFunction utility | titio | OpenFOAM Post-Processing | 0 | May 19, 2010 16:04 |
