Home > Forums > OpenFOAM Programming & Development
data.solverPerformance.tg at line 0.
Old   November 18, 2014, 01:49
Default data.solverPerformance.tg at line 0.
Thamali
Thamali is on a distinguished road
Dear Foamers,
I am solving a case using an Euler-Euler solver developed for combustion of wood chips.
When I run the case using the solver,it stops at calculating "rCH4" and FPE error appears.
#0  Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/printStack.C:221
#1  Foam::sigFpe::sigHandler(int) at ~/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/signals/sigFpe.C:117
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3   in "/lib/x86_64-linux-gnu/libm.so.6"
#4  Foam::pow(double, double) at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/doubleFloat.H:78
#5  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/fields/Fields/scalarField/scalarField.C:118 (discriminator 2)
#6  void Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/GeometricScalarField.C:274
 at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/GeometricScalarField.C:328
 at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/GeometricScalarField.C:350 (discriminator 1)
 at ~/OpenFOAM/thamali-2.2.2/applications/solvers/latest/testonlymoistandcharnpyrovolat/UEqn1.H:95 (discriminator 1)
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
 at ??:?
Floating point exception (core dumped)
But,when I check the parameters YCH4,YO2 or tg of previous time step necessary for calculation,all are positive values.
When I,unset FOAM_SIGFPE,
The "rCH4" become negative at 2 points(1 point in a boundary and 1point in internalField).
wrong token type - expected Scalar, found on line 0 the word 'nan'
file: /home/thamali/OpenFOAM/thamali-2.2.2/run/tutorials/combustion/woodchipcombustion/new/latest/withwallradiation/test/drypyrochacovolat/system/data.solverPerformance.tg at line 0.
    From function operator>>(Istream&, Scalar&)
    in file lnInclude/Scalar.C at line 91.
FOAM exiting
I checked case log and for tg;
smoothSolver:  Solving for tg, Initial residual = nan, Final residual = nan, No Iterations 1000
I tried by changing "fvSchemes " and they did not work.
I am attaching the files calculating "rCH4" and file calculating Gasphase mas fractions(Y) and tg.
I highly appreciate your help.
If you want to look at other files of the solver,I am happy put upload.
Thanks in advance.
Regards,
Thamali
Thamali is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit OpenFOAM Paraview & paraFoam 60 September 18, 2013 03:23
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
