Home > Forums > OpenFOAM Programming & Development
error in operator& use
Old   November 26, 2014, 10:30
Default error in operator& use
Bharat Bhushan Sharma
bharat.gmail is on a distinguished road
Dear All Foamers,
I am bit new to openfoam programming and have been working on writing a solver based on existing solver. But I am getting following error. Can you tell me what is the problem. Actually same piece of code works very well in other solvers but in my code, while compiling I get error's mentioned below.
CODE:
surfaceScalarField phiUf("phiUf",(fvc::interpolate(phiU,"phiU")) & mesh.Sf());
//- phiH
surfaceScalarField phiH("phiH", (fsf*Kf*(ROL-ROV)*hlg*g/nuv) & mesh.Sf());
ERROR'S:
updateSbProperties.H:95:51: error: no match for ‘operator&’ in ‘Foam::fvc::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&) [with Type = double]((* & Foam::word(((const char*)"phiU"), 1))) & mesh.Foam::fvMesh::Sf()’
updateSbProperties.H:95:51: note: candidates are:
/opt/openfoam230/src/OpenFOAM/lnInclude/wordI.H:167:19: note: Foam::word Foam::operator&(const Foam::word&, const Foam::word&)
/opt/openfoam230/src/OpenFOAM/lnInclude/wordI.H:167:19: note:   no known conversion for argument 1 from ‘Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >’ to ‘const Foam::word&’
/opt/openfoam230/src/OpenFOAM/lnInclude/FieldFunctions.C:774:1: note: template<class Type1, class Type2> Foam::tmp<Foam::Field<typename Foam::innerProduct<Type1, Type2>::type> > Foam::operator&(const Foam::UList<T>&, const Foam::UList<StringType>&)
/opt/openfoam230/src/OpenFOAM/lnInclude/FieldFunctions.C:774:1: note: template<class Type1, class Type2> Foam::tmp<Foam::Field<typename Foam::innerProduct<Type1, Type2>::type> > Foam::operator&(const Foam::UList<T>&, const Foam::tmp<Foam::Field<Type2> >&)
/opt/openfoam230/src/OpenFOAM/lnInclude/FieldFunctions.C:774:1: note: template<class Type1, class Type2> Foam::tmp<Foam::Field<typename Foam::innerProduct<Type1, Type2>::type> > Foam::operator&(const Foam::tmp<Foam::Field<Type> >&, const Foam::UList<StringType>&)
/opt/openfoam230/src/OpenFOAM/lnInclude/FieldFunctions.C:774:1: note: template<class Type1, class Type2> Foam::tmp<Foam::Field<typename Foam::innerProduct<Type1, Type2>::type> > Foam::operator&(const Foam::tmp<Foam::Field<Type> >&, const Foam::tmp<Foam::Field<Type2> >&)
You can see that this code for getting phi is standard and is giving no error in original solver but I dont understand why I am getting these mismatch error's for operator&.
Please tell me how to sort it out.
Thanks & Regards,
bharat.gmail is offline   Reply With Quote
Old   November 26, 2014, 10:43
floquation's Avatar
Kevin van As
floquation is on a distinguished road
What OF version are you using?
I'm not an expert, but judging from the error and judging from a search on "fvc::interpolate" (in OF-2.3.x), I can't help but notice that your interpolate has two arguments, whereas the search results always (I went through the first 40 results) have one argument.
So change
to
surfaceScalarField phiUf("phiUf",(fvc::interpolate(phiU)) & mesh.Sf());
and see if that works.
floquation is offline   Reply With Quote
Old   November 26, 2014, 18:58
So change
to
I tried your suggestion but same errors came again. I think it has some thing to do with the datatype of return value of fvc::interpolate(phiU). Thanks for your reply. ANd mine is version 2.3.0-OF.
Please somebody suggest me what I have to do to remove this error.
Thanks & Regards,
BHarat Bhushan Sharma
Old   December 6, 2014, 06:53
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@Bharat Bhushan Sharma: The problem is that you're trying to interpolate a surface scalar field, which isn't a standard interpolation in OpenFOAM. As detailed here: https://github.com/wyldckat/reconstr...te-fields/wiki
More specifically, it will interpolate the fields that exist in the cell centres onto the face centres. This operation is only done for the following field interpolations:
  • Interpolate volScalarField to surfaceScalarField.
  • Interpolate volVectorField to surfaceVectorField.
Best regards,
Bruno
Thread Tools
Trackbacks are On
