Implementing kEpsilon turbulance mode with the airfoil example.....
Old   December 8, 2014, 00:18
Default Implementing kEpsilon turbulance mode with the airfoil example.....
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hey Foamers,
I have implemented kOmega turbulence model in the airfoil2d example. However, when I switched to kepsilon turbulence model following all required steps, simpleFoam was unable to run. In the 0 folder, I put k and epsilon folders, and I deleted the file nuTilda and that is based on what I have read on the CFD forum.
My k is:
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 0.01;
boundaryField
inlet
type fixedValue;
value uniform 0.01;
outlet
type zeroGradient;
walls
type kqRWallFunction;
value uniform 0.01;
frontAnBack
type empty;
My epsilon file is
dimensions [ 0 2 -3 0 0 0 0 ];
internalField uniform 4.85;
boundaryField
inlet
type fixedValue;
value $internalField;
outlet
type zeroGradient;
walls
type epsilonWallFunction;
frontAndBack
type empty;
fscheme is
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
fsolution is
solvers
p GAMG
tolerance 1e-16;
relTol 0.01;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
minIter 0;
maxIter 1000;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
scaleCorrection true;
directSolveCoarsest false;
Urel smoothSolver
nSweeps 1;
tolerance 1e-16;
relTol 0.01;
maxIter 500;
k smoothSolver
nSweeps 1;
tolerance 1e-16;
relTol 0.01;
maxIter 500;
epsilon smoothSolver
nSweeps 1;
tolerance 1e-16;
relTol 0.01;
maxIter 500;
omega smoothSolver
nSweeps 1;
tolerance 1e-16;
relTol 0.01;
maxIter 500;
SIMPLE
nNonOrthogonalCorrectors 0;
relaxationFactors
fields
p 0.3;
equations
Urel 0.6;
k 0.5;
epsilon 0.5;
omega 0.5;
R 0.5;
nuTilda 0.5;
Can somebody explain why it is not working?
Thank you....
tareqkh is offline   Reply With Quote
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
