adding strainRate in a solver
Like Tree5Likes
  • 1 Post By kmooney
  • 1 Post By wyldckat
  • 2 Post By Mahyar Javidi
Old   December 17, 2014, 16:54
Default adding strainRate in a solver
anonymous
Mahyar Javidi is on a distinguished road
Hello everyone
I want to add strain rate in interFoam and I do not know how to do that. I need to define one more equation to interFoam similar to the temperature but for volume fraction and I wrote the code for solving the matrix but still have a problem with strain rate.
I defined viscosity like:
surfaceScalarField mu=fvc::interpolate(twoPhaseProperties.mu());
and I tried to define strain rate like:
surfaceScalarField strainRate=fvc::interpolate(viscosityProperties.st rainRate());
which it seems the definition of strain rate is not correct. Do I need to declare sth in creatFields.H for it?
Could anyone help me coding this part.
Regards
Mahyar
Mahyar Javidi is offline   Reply With Quote
Old   December 19, 2014, 14:26
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Hi Mahyar,
You could always calculate the strain rate values with something like this in the top level solver:
volScalarField strainRate = sqrt(2.0)*mag(symm(fvc::grad(U)));
surfaceScalarField strainRatef = fvc::interpolate(strainRate);
On another look it seems that the incompressibleTwoPhaseMixture class has a public access function to the viscosityModel class.
Something like this might work as well (warning:untested):
surfaceScalarField strainratef = fvc::interpolate(twoPhaseProperties.nuModel1().strainRate());
I hope that helps!
Cheers,
Kyle
Originally Posted by Mahyar Javidi View Post
Hello everyone
Regards
Mahyar
alainislas likes this.
kmooney is offline   Reply With Quote
Old   December 23, 2014, 09:50
anonymous
HiKyle
Thanks for your reply. I tried the first part of the code that you mentioned beforein my code and I got an error about the type that strainRate returns (which is double).
I was wondering should I define an object for viscosityModel class and use strainRate function through that object. I think this is the case for twophaseProperties.
Best Regards
Mahyar
Old   December 23, 2014, 15:25
kmooney's Avatar
Kyle Mooney
Hi Mahyar,
I'm confused by your statement. How can strainRate return a double if you're initializing the variable to be type volScalarField?
Kyle
Old   January 8, 2015, 15:28
anonymous
Dear Kyle
sorry for the late reply.
This is the exact error that I receive when I used the definition of strainRate in the code.
error: call of overloaded ‘sqrt(double)’ is ambiguous
regards
Mahyar
Old   January 8, 2015, 15:30
kmooney's Avatar
Kyle Mooney
try
foam::sqrt
instead
Old   January 8, 2015, 15:37
anonymous
Hi
I used volScalarField strainRate = foam::sqrt(2.0)*mag(symm(fvc::grad(U)));
and I got this: error: ‘foam’ has not been declared
Regards
Mahyar
Old   January 8, 2015, 15:39
kmooney's Avatar
Kyle Mooney
you could always just use 1.41421356237!
Old   January 8, 2015, 15:51
anonymous
Thanks Kyle. The solver compiled now.
Old   January 8, 2015, 15:52
Retired Super Moderator
Bruno Santos
Greetings to all!
This is one of those frequently asked questions... gotta make a note to add this to the FAQ...
Mahyar, please try the following:
::sqrt(2.0)
::sqrt(scalar(2.0))
sqrt(scalar(2.0))
scalar(::sqrt(2.0))
scalar(sqrt(2.0))
I don't have time to test any of them right now, but I do vaguely remember that said error message can be overcome with one or more of the above.
Best regards,
Bruno
kmooney likes this.
Old   January 8, 2015, 16:06
anonymous
Hi Bruno
I checked them in my solver and the results are:
scalar(sqrt(2.0)) error: call of overloaded ‘sqrt(double)’ is ambiguous, note: Foam::doubleScalar Foam::sqrt(Foam::doubleScalar)
scalar(::sqrt(2.0)) It works
sqrt(scalar(2.0)) error: call of overloaded ‘sqrt(double)’ is ambiguous
::sqrt(scalar(2.0)) It works
::sqrt(2.0) It works
Regards
Mahyar
wyldckat and rudolf.hellmuth like this.
Old   January 11, 2015, 14:53
Bruno Santos
Hi Mahyar,
Many thanks for testing them all! I've added the working ones to the FAQ: http://openfoamwiki.net/index.php/FA...9_is_ambiguous
Best regards,
Bruno
rudolf.hellmuth likes this.
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 08:43
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Adding additional complex source term to BuoyantBoussinesqPisoFoam solver pajofego OpenFOAM Programming & Development 2 April 9, 2013 17:00
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
