January 7, 2015, 10:11 |
janaf dynamic
sebastien vilfayeau
Rep Power: 14 |
I'm working on fireFoam and I try to implement a new model. For this model, I need to have access to polynomial Janaf coefficients defined in "constant/thermo.compressibleGas". My solution was to use a dynamic_cast inside my code as follows : Code:
// Setup the janaf thermo class typedef janafThermo<perfectGas<specie> > janafType; typedef sutherlandTransport<sensibleEnthalpy<janafType> > thermoType; const multiComponentMixture<thermoType>& myThermo = dynamic_cast<const multiComponentMixture<thermoType>&>(this->thermoPtr_()); // O2 thermal enthalpy // Oxygen label const label specie_O2 = this->thermoPtr_->composition().species()["O2"]; // Compute janaf class for O2 const janafType& myThermo_O2 = dynamic_cast<const janafType&>(myThermo.speciesData()[specie_O2]); // Compute molecular thermal enthalpy [J/kmol] scalar H_O2 = myThermo_O2.hs(1e5, Tair_); // Compute molecular weight [kg/kmol] scalar MW_O2 = this->thermoPtr_->composition().W(specie_O2); // Calculate thermal enthalpy [J/kg] scalar hs_O2 = H_O2/MW_O2; Info << "hs_O2 = " << hs_O2 << endl; cannot dynamic_cast ... (source type is not polymorphic) Anyone has a hint how to solve this problem? Thanks Sebastien |
July 26, 2017, 11:24 |
Rep Power: 11 |
This thread is quite old, however maybe it's still a useful reply for someone.
The error message "type is not polymorphic" refers at least to the type of speciesData()[specie_O2] in Code:
const janafType& myThermo_O2 = dynamic_cast<const janafType&>(myThermo.speciesData()[specie_O2]); |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
Dynamic SGS model procedure in Large eddy simulation | mrf6166 | Main CFD Forum | 39 | November 25, 2016 14:13 |
Dynamic contact angle | raj kumar saini | Fluent UDF and Scheme Programming | 0 | October 13, 2014 02:18 |
Entropy calculation in OpenFoam | immortality | OpenFOAM | 23 | September 8, 2013 17:18 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
