energy equation problem
Old   January 12, 2015, 02:12
Default energy equation problem
Gary51075607 is on a distinguished road
hello, eveybody
i'm a new in learning OpenFoam and have problems in reading the EEqn.H in the solver of buyoantSimpleFoam.
what do the follwing secentences respect for?
he.name() == "e"
? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho))
: fvc::div(phi, volScalarField("K", 0.5*magSqr(U)))
and i also doubt about the "fvOptions" followed.
Gary51075607 is offline   Reply With Quote
Old   January 12, 2015, 03:17
Fabian Roesler
fabian_roesler is on a distinguished road
Hi Gary
he.name() == "e"
is an if structure to decide whether to use
internal energy
or enthalpy
formulation, where 0.5*magSqr(U) is specific kinetic energy and p/rho should be a work term.
+ fvOptions(rho, he)
fvOptions is a kind of library where options like porous media, SRF/MRF and sources for all solvers are implemented. So if you choose to add a source term for a specific cell zone, this will be handled here.
Hope this helps a bit.
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   January 12, 2015, 07:55
Thank you very much, Febian. Now i can completely understand it
Regard,
Gary
Old   January 29, 2015, 03:52
Hi, Fabian
Now i want to add a source term in the energy equation using the fvOptions. where can i get enough info about it?
Regards!
Gary
Old   February 20, 2015, 04:36
Fabian Roesler
Browse the tutorials and you will find everthing you need:
energySource1
    type            scalarSemiImplicitSource;
    active          true;
    timeStart       0.2;
    duration        2.0;
    selectionMode   points;
    points
        (2.75 0.5 0)
    scalarSemiImplicitSourceCoeffs
        volumeMode      absolute;
        injectionRateSuSp
            h           (10 0);
source1
    type            fixedTemperatureConstraint;
    active          true;
    timeStart       0.1;
    duration        0.4;
    selectionMode   cellSet;
    cellSet         ignitionCells;
    fixedTemperatureConstraintCoeffs
        mode            uniform;
        temperature     2000;
Old   August 7, 2015, 07:55
Default What "ekp" stands for in EEqn.h file in rhoPorousSimpleFoam
Umesh
umeshisode is on a distinguished road
Hello Everybody,
I am trying to understand a rhoPorousSimpleFoam solver but stuck in the file EEqn.h at solvers directory.
fvScalarMatrix EEqn
fvm::div(phi, he)
he.name() == "e"
- fvm::laplacian(turbulence->alphaEff(), he)
fvOptions(rho, he)
In above code what is "Ekp" and "K" stands for .
And one more question, how to get value in "fvOptions(rho, he)".
Thanks in advance. Waiting for your reply.
umeshisode is offline   Reply With Quote
eeqn.h
error message cuteapathy CFX 14 March 20, 2012 06:45
Energy equation in bouyant*Foam solvers makaveli_lcf OpenFOAM Running, Solving & CFD 0 December 21, 2009 04:09
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 14:01
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 10:21
Problem with Joulebs effect source term in the energy equation galaad OpenFOAM Running, Solving & CFD 0 January 19, 2006 12:01
