Symbol lookup error for special solvers
Like Tree3Likes
  • 2 Post By deepsterblue
  • 1 Post By deepsterblue
Old   November 29, 2016, 15:26
Default Symbol lookup error for special solvers
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear all,
I am facing a problem that I could not resolve till now. To my problem: I build a new boundary condition (Robin BC based on the mixedFvPatchField class; the library can be downloaded and used from my bitbucket account: https://bitbucket.org/shor-ty/laserconvectionbc/). However, the library is working fine in my Ph.D. solver as well as for the basic laplacianFoam solver. Trying to use the boundary within the heat-transfer solver lead to the following symbol lookup error:
buoyantPimpleFoam: symbol lookup error:  /home/shor-ty/OpenFOAM/shor-ty-dev/platforms/linux64GccDPInt32Opt/lib/liblaserConvectionBC.so:  undefined symbol:  _ZN4Foam27laserConvectionFvPatchFieldIdEC1ERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE
Normally, I guess that this error indicates a missing library. However, even if I use the debug compiled FOAM version, I cannot get more information out of the problem and I could not find any library that is missing to resolve this issue.
Any hint is highly appreciated.
Thanks in advance,
Edit: I figured out that it is not working with laplacianFoam either, so finally I got the error always (only if I compile it direct with my solver); ... (confused)
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   November 29, 2016, 15:38
Sandeep Menon
deepsterblue will become famous soon enough
c++filt on your symbol gives me this:
c++filt _ZN4Foam27laserConvectionFvPatchFieldIdEC1ERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE
Foam::laserConvectionFvPatchField<double>::laserConvectionFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&)
Do you have this constructor implemented in your source file?
Kummi and allanZHONG like this.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   November 29, 2016, 15:54
Tobi's Avatar
Tobias Holzmann
yes I have this constructor implemented:
template<class Type>
Foam::laserConvectionFvPatchField<Type>::laserConvectionFvPatchField
    const fvPatch& p,
    const DimensionedField<Type, volMesh>& iF,
    const dictionary& dict
Keep foaming,
Tobias Holzmann
Old   November 29, 2016, 16:44
Sandeep Menon
Alright... And has it been instantiated for 'double'? You need to have this line defined somewhere:
makePatchFields(laserConvection)
Sandeep Menon
Old   November 29, 2016, 17:48
Tobi's Avatar
Tobias Holzmann
Thanks for your reply. For sure I have this line. You can check the stuff here: https://bitbucket.org/shor-ty/laserconvectionbc/src and try it yourself. The class is a template class.
Keep foaming,
Tobias Holzmann
Old   November 30, 2016, 03:19
Tobi's Avatar
Tobias Holzmann
I just want to mention that the boundary condition works fine if we compile it within the solver. However, the standalone library would be much better. Any hint is appreciated. Thanks in advance.
Keep foaming,
Tobias Holzmann
Old   November 30, 2016, 10:46
Sandeep Menon
Why are these lines commented out:
#ifdef NoRepository
#   include "laserConvectionFvPatchField.C"
#endif
That's the line which includes all your template code. When I uncomment it, it compiles fine, and the output of
nm liblaserConvectionBC.so | c++filt
yields weak symbols instead of undefined. I haven't tried including your library in a solver. Perhaps you could try it and let me know.
PS. You probably want to replace std::to_string (C++11 only) with Foam::name if you want portability.
Tobi likes this.
Sandeep Menon
Old   November 30, 2016, 15:22
Thumbs up
Tobi's Avatar
Tobias Holzmann
thanks for the remark. I comment this lines because I got a previous declared here error. However, I realized that at the beginning I was compiling the wrong *.C file. Thats why this commented lines still were in the code. Now it is fine after uncommenting the lines again and checking everything again.
By the way I was also trying to uncomment the lines. It was not working. I forgot to wclean it.
Thank you very much.
Keep foaming,
Tobias Holzmann
Old   November 18, 2018, 09:33
gu1
Guilherme
gu1 is on a distinguished road
I apologize for opening the thread again, but I had a similar error. My library compiles normally, but when I start the simulation... the solver has the same error as described above. Could you help me?
turbulentFoam: symbol lookup error: turbulentFoam: undefined symbol: _ZN4Foam17turbulentModelC1ERKNS_14GeometricFieldIN S_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1 _IdNS_13fvsPatchFieldENS_11surfaceMeshEEE
.C:
Foam::turbulentModel::turbulentModel
const volVectorField& U,
const surfaceScalarField& phi,
IOdictionary
IOobject
"turbulentProperties",
U.time().constant(),
U.db(),
IOobject::MUST_READ,
IOobject::NO_WRITE
rho_(dict.lookup("rho")),
tau_(dict.lookup("tau")),
lawPtr_(turbulentLaw::New(word::null, U, phi, subDict("Stress")))
.H:
class turbulentModel
public IOdictionary
dimensionedScalar rho_;
dimensionedScalar tau_;
public:
TypeName("turbulentModel");
// Constructors:
turbulentModel
gu1 is offline   Reply With Quote
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
Symbol lookup error after upgrading to 2.1.1 ChrisA OpenFOAM Programming & Development 2 March 6, 2013 20:38
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
