Eulerian multiphase tracer transport - value of scalar?
Old   January 14, 2015, 09:44
Default Eulerian multiphase tracer transport - value of scalar?
Dominik Schmidt
dschmidt is on a distinguished road
Dear Foamers,
I believe the answer to my question is quite simple, but I couldn't find a clear definition for it:
I'm adding a scalar transport equation to an incompressible multiphase solver, where the scalar should only be transported by/in the liquid phase,
representing e.g. a solution of salt in water.
\frac{\partial {\alpha_L Tr}}{\partial {t}} + \nabla \cdot (\alpha_L U_L Tr) = \nabla \cdot (\alpha_L \Gamma) \nabla Tr)
fvm::ddt(alpha1, Tracer)
+ fvm::div(fvc::interpolate(alpha1)*phi1, Tracer)
- fvm::laplacian(fvc::interpolate(alpha1)*DT, Tracer)
Assuming this part is correct (please correct me, if it isn't),
my questions is about the "value" of the transported scalar:
1.) "Tracer" = mass(Tracer) per cell-volume (= concentration in each cell)?
... so to get the concentration in the liquid phase in each cell one has to divide "Tracer"-value by alpha1 (volumetric phase fraction of liquid phase)?
or
2.) the value for "Tracer" already represents the concentration in the liquid phase?
or
3.) anything else?
In short: Does the Tracer-value represent a concentration based on the cell volume or based on the liquid volume in each cell?
Or is a completely different approach necessary to get the concentration of e.g. a salt in the water phase for the evaluation of homogeneity inside the domain.
Thanks for your help!
Dominik
EDIT:
Reading http://www.sciencedirect.com/science...85894714015587 helped me to understand that the second option should be correct.
dschmidt is offline   Reply With Quote
Old   February 1, 2015, 23:21
Alberto Passalacqua
Yes, your equation is correct and refers to a tracer into the liquid phase (note that alpha_L is in all the terms).
Alberto Passalacqua
Old   November 18, 2018, 23:26
Niu
Z.Q. Niu is on a distinguished road
Hi Dominik,
I have also write a same equation in the interFoam solver to add tracker into one phase of interFoam. But I found if alpha1 equals zero, the solver will crash, unlesss you set a small value for alpha1, e.g. 1e-6 or smaller one. Did you have this situation? It will be great if you cold you share your code! The following is my code:
fvm::ddt(alpha1, CFai)
+ fvm::div(fvc::interpolate(alpha1)*phi, CFai)
- fvm::laplacian(fvc::interpolate(alpha1)*DT_L, CFai)
Z.Q. Niu is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
problems concerning mass conservativity in bubbleFoam with custom scalar transport cutter OpenFOAM Programming & Development 3 February 10, 2015 04:25
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 06:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
