Spanwise averaging during runtime for dynamic Smagorinsky |
January 30, 2015, 15:27 |
Karthik Rudra Reddy
Rep Power: 12 |
Hello all,
Does anyone know if we can average a variable along a single direction (say spanwise) during runtime? Specifically, I want to do spanwise averaging while calculating LL, MM in the homogenousDynSmagorinsky LES model, instead of averaging over the whole domain, like it seems to be doing now. Just for a quick reference, here's the portion of the model in homogenousDynSmagorinsky.C where the model constant is being calculated. Code:
dimensionedScalar homogeneousDynSmagorinsky::cD ( const volSymmTensorField& D ) const { const volSymmTensorField MM ( sqr(delta())*(filter_(mag(D)*(D)) - 4*mag(filter_(D))*filter_(D)) ); dimensionedScalar MMMM = average(magSqr(MM)); if (MMMM.value() > VSMALL) { tmp<volSymmTensorField> LL = dev(filter_(sqr(U())) - (sqr(filter_(U())))); return 0.5*average(LL && MM)/MMMM; } else { return 0.0; } } Please let me know if any of you have any ideas. |
February 12, 2015, 13:13 |
Zifei Yin
Rep Power: 13 |
Good question, karthik. -- Zifei
use a structured solver maybe -- Umair |
February 12, 2015, 13:40 |
Karthik Rudra Reddy
Rep Power: 12 |
February 18, 2015, 08:20 |
Armin
Rep Power: 19 |
I don't really have an answer to your question, other than implementing the functionality on your own using for-loops and if-statements.
However, since you are not the only one with this problem, there are quite some papers that address this issue, my favorite (with respect to dynamic coeff evaluation) would be the Lagrangian averaging proposed by Meneveau et al. (1996): Meneveau, Charles, Thomas S. Lund, and William H. Cabot. “A Lagrangian Dynamic Subgrid-Scale Model of Turbulence.” Journal of Fluid Mechanics 319 (July 1996): 353–85. doi:10.1017/S0022112096007379. The next OpenFOAM version will have this model implemented, see here: https://github.com/OpenFOAM/OpenFOAM...icLagrangian.H |
les, spanwise average |
Spanwise averaging of three-dimensional field | Fuchs | OpenFOAM Post-Processing | 47 | December 1, 2021 08:59 |
Difference between Constant smagorinsky and Dynamic model Smagorinsky model | cfdmms | Main CFD Forum | 8 | January 21, 2016 04:44 |
Starting field averaging using libFunctionObject after certain time | eelcovv | OpenFOAM Programming & Development | 25 | December 7, 2015 22:28 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
spanwise averaging for LES backward facing step | Sungho Yoon | CFX | 6 | July 23, 2008 10:34 |
