February 27, 2015, 22:24 |
cellCells() parallel
Rep Power: 13 |
Hi foamers,
I am doing a simulation that requires me to find neighbour cells of certain cells in a domain. cellCells() works fine for serial run but fails to look for all neighbour cells in parallel: it only looks for cells in processor0. I tried to use Pstream but it fails every time when I try to run in parallel. Below is my code. forAll(mesh_.cellCells()[idCell[a]], b)//Create a list for neighbour cells of idCell { labelList pnCell(Pstream::nProcs(),0); pnCell[Pstream::myProcNo()] = mesh_.cellCells()[idCell[a]][b]; reduce(pnCell, maxOp<labelList>()); forAll(pnCell, c) { nCell.resize(c+1); nCell[c] = pnCell[c]; } pnCell.clear(); } and the error message is [2] --> FOAM FATAL IO ERROR: [2] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token [2] [2] file: IOstream at line 0. [2] [2] From function IOstream::fatalCheck(const char*) const [2] in file db/IOstreams/IOstreams/IOstream.C at line 114. [2] FOAM parallel run exiting [2] Anyone has suggestions as to how to solve this problem? Best regards, Carlen |
November 16, 2017, 05:40 |
Hi
Rep Power: 16 |
Any answer for this problem ? or not yet
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 04:38 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
