Home > Forums > OpenFOAM Programming & Development
combining fluid structure in parallel
Old   March 3, 2015, 04:37
Default combining fluid structure in parallel
Carlen is on a distinguished road
Hi foamers,
I am working on a case that requires me to combine a continuous fluid structure (say a droplet) separated by a processor patch. To do this, I need to know the cell IDs of each processor in order for me to combine such a fluid structure. However, the cellIDs of the decomposed domains are not consecutive. Therefore, I am wondering if I could renumber the mesh in order to make all faces, cells and points consecutive in all sub domains. To make this easier to understand, suppose we have a square computational domain with a cell number of 50000. In serial mode, the cellIDs are numbered from 1 to 50000. In parallel mode, as the domain is decomposed, each domain has their unique set of cellIDs starting from 0. So for processor 0, the cellIDs are from 0 to 12500 as the same is for other domains.
How can I make cellIDs for the above case go from 0-50000 for a decomposed mesh?
I very much appreciate your help.
Best regards,
Carlen
Carlen is offline   Reply With Quote
Thread Tools
Trackbacks are On
Fluid Structure Interation Problem Vino Main CFD Forum 5 August 24, 2013 14:23
Thermal fluid structure interaction SamerAli FLUENT 1 July 23, 2013 16:36
[ANSYS Meshing] How to match mesh elements in fluid structure interface faraday34 ANSYS Meshing & Geometry 0 June 18, 2013 17:24
Fluid structure interaction. Haree FLUENT 2 August 7, 2010 02:56
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
