April 2, 2015, 05:12 |
meshToMesh every timestep parallel OF2.3.1
Rep Power: 13 |
Hi foamers,
I want to map fields from a fine mesh to a coarse mesh on a regular basis (every timestep). I have searched many posts in this forum and found these very useful: http://www.cfd-online.com/Forums/ope...time-step.html http://www.cfd-online.com/Forums/ope...-parallel.html http://www.cfd-online.com/Forums/ope...shes-used.html However, I am rather confused about how in above implementations the createMesh.H and createFields.H are written. I understand you have to have the sourcemesh and targetmesh for mapping, and you define them separately by Code:
Foam::fvMesh mesh ( Foam::IOobject ( "Primary", //I have two regions of same geometry (Primary and Secondary) runTime.timeName(), runTime, Foam::IOobject::MUST_READ ) ); Foam::fvMesh mesh2 ( Foam::IOobject ( "Secondary", runTime.timeName(), runTime, Foam::IOobject::MUST_READ ) ); My question is for the mesh2 part. As I understand that in createFields.H all IOobject use mesh, e.g. Code:
volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Or is there another way to do calculations on two meshes in one solver? PS: I just want to know how the creatMesh.H and createFields.H are written for such a purpose |
April 2, 2015, 09:44 |
#2 | |
Ryan Tunstall
Rep Power: 12 |
A good way to approach this is using multiple regions. That way existing utilities like decomposePar etc will be compatible with your new solver. Basically have a look at chtMultiRegionFoam and how it makes use of regionProperties. Basically you want to set it up so that each mesh is a different region. Then instead of having a volVectorField for U on each mesh you can have a single PtrList of length 2 where each element in the PtrList is a pointer to the U field on that mesh |
April 2, 2015, 10:39 |
Rep Power: 13 |
Hi Ryan,
Thank you very much for your reply. Yes I have setup my code in a way similar to the solver you mentioned. I have two regions (Primary and Secondary) for fine and coarse meshes, and they have identical geometry and boundary conditions. So I can decompose it using decomposePar -region Primary or Secondary respectively. However, I am confused by the use of PrtList as I am new to OpenFoam. How is it implemented? kind regards, carlen |
April 2, 2015, 10:52 |
Rep Power: 13 |
Hi Ryan,
is this correct. I have to have U for the fine mesh and Utgt for the coarse mesh. I then write Code:
PrtList<fvMesh> fluidRegions(2); forAll(fluidRegions, i) { fluidRegions.set ( i, new fvMesh ( IOobject ( fluidNames[i], runTime.timeName(), runTime, IOobject::MUST_READ ) ) ); } Then in createFields, Code:
volVectorField U ( IOobject ( "U", runTime.timeName(), Primary, IOobject::MUST_READ, IOobject::AUTO_WRITE ), Primary ); volVectorField Utgt ( IOobject ( "U", runTime.timeName(), Secondary, IOobject::MUST_READ, IOobject::AUTO_WRITE ), Secondary ); Also, I notice that many equations in my solver needs mesh for example in the readGravitatioanlAcceleration.H it needs the registry to be mesh not my Primary and Secondary registries. Does that mean I have to modified all related openFoam files and recompile the whole OpenFoam. Or is there any other way to do it? Best, carlen |
April 2, 2015, 10:53 |
#5 | |
Ryan Tunstall
Rep Power: 12 |
PtrList<volVectorField> UFluid(fluidRegions.size()); forAll(fluidRegions, i) { Info<< " Adding to UFluid\n" << endl; UFluid.set ( i, new volVectorField ( IOobject ( "U", runTime.timeName(), fluidRegions[i], IOobject::MUST_READ, IOobject::AUTO_WRITE ), fluidRegions[i] ) ); } The ptrList UFluid is then a bit like a 1D array, there is an element for each fluid region and each element contains a pointer to the volVectorField created. So if you do UFluid[1] you will get the U field for mesh1 and if you do UFluid[2] you will get the U field for mesh 2. This means we don't have to clutter the programme up with lot's of variable names, can make use of loops for more concise code etc. Best of all it is very generic, so we can have more than two meshes if we want to. Note that you can create a PtrList for a volScalarField etc too |
April 2, 2015, 11:00 |
#6 | |
Ryan Tunstall
Rep Power: 12 |
April 2, 2015, 11:09 |
Rep Power: 13 |
Thank you very much Ryan,
Now I feel more confident writing my own solver. One more question, do I need to make changes to Ueqn, pEqn etc.? because from what I see they use Code:
fvc::interpolate(rho*HbyA) & mesh.Sf() kind regards, carlen |
April 2, 2015, 11:21 |
#8 | |
Ryan Tunstall
Rep Power: 12 |
volVectorField& U = UFluid[i]; I think this is just done to make the code that follows more concise. However I find it easier to just use the existing PtrList, so if I want U from mesh i I put UFluid[i]; then there is no need for setRegionFluidFields.H |
April 2, 2015, 11:49 |
#9 |
Rep Power: 13 |
Thank you Ryan!
That's much more clear! I will try to write my solver and can I get back to you if I have more questions? Best, carlen |
MeshToMesh parallel | ganeshv | OpenFOAM Programming & Development | 17 | December 21, 2023 13:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
Parallel running runtime modifiable timestep | sampaio | OpenFOAM Running, Solving & CFD | 1 | May 26, 2005 19:18 |
transient, parallel - problem with timestep | Peter | CFX | 5 | March 8, 2005 16:15 |
