Home > Forums > OpenFOAM Programming & Development
setReference in fvMatrix.C
Old   April 16, 2015, 05:45
Default setReference in fvMatrix.C
Andre Weiner
andre.weiner is on a distinguished road
Hello Foamers!
The method setReference is widely used in OpenFOAM, for instance to set a reference pressure in simulations without a boundary with fixed pressure value. It's body looks the following:
line 517-520 in fvMatrix.C
        source()[celli] += diag()[celli]*value;
        diag()[celli] += diag()[celli];
My Question: Why do I arrive at the defined value by manipulating the diagonal matrix coefficient and the source in the given way?
Many thanks in advance!
Best, Andre
andre.weiner is offline   Reply With Quote
Old   April 24, 2015, 06:59
Dongyue Li
sharonyue is on a distinguished road
Originally Posted by andre.weiner View Post
Hello Foamers!
Best, Andre
I wrote it down and hopes this will give u some hints. pls see the image. Hopes im right
oh this image is way too big...Sorry about that, Im shocked...
sharonyue is offline   Reply With Quote
Old   April 24, 2015, 11:30
Andre Weiner
Ciao sharonyue!
Thanks a lot for your small example. I tried to formulate it a little bit more general
For each cell center P with the neighbours nb we can write the equation
a_P\ \varphi_P + \sum_{nb} a\varphi = S_\varphi
or
a_P\ \varphi_P + \sum_{nb} a\varphi - S_\varphi = 0 \ \ \ \ (1)
What we want is to set for a given P
\varphi_P = \varphi_{ref}
To incorporate this condition into outer algebraic system, first we multiply by a_P
a_P\varphi_P=a_P\varphi_{ref}
To this equation we now add (1) (we are adding 0) and get
a_P\ \varphi_P + a_P\ \varphi_P + \sum_{nb} a\varphi - S_\varphi = a_P\ \varphi_{ref}
which is reordered
2 a_P\ \varphi_P + \sum_{nb} a\varphi  = S_\varphi+ a_P\ \varphi_{ref}
This approach almost seems to simple and effective to be true
On the one hand you do not destroy the conditioning of the Matrix by applying some huge value to the diagonal and the source, and on the other hand the symmetry of the matrix is conserved (it would be also possible to set the off-diagonal coefficients to zero).
Thanks again for the support!
Best, Andre
Old   April 25, 2015, 04:19
Dongyue Li
Ciao sharonyue!
or
which is reordered
Best, Andre
Neat! quite clear and simple,
Never too old to learn CFD. haha.
Best,
dongyue
Thread Tools
Trackbacks are On
Some misleading about the treatment of coupled boundary liuhuafei OpenFOAM Bugs 4 February 22, 2014 16:01
Poisson eq w setReference works serial diverges in parallel tehache OpenFOAM Running, Solving & CFD 5 August 29, 2012 09:41
Appropriate boundary conditions for external incompressible flow mattamos OpenFOAM Running, Solving & CFD 7 July 28, 2005 12:03
