How to extract part of a library?
Old   May 2, 2015, 01:03
Default How to extract part of a library?
Di Cheng
chengdi is on a distinguished road
Hi, everyone
I am using LEMOS to do POD analysis. But I need to modify some file slightly. What is the best way to do that?
I copied
$LEMOSEXT/libLEMOS-2.3.x/postProcessing/POD
to
$WM_PROJECT_USER_DIR
and copied the Make directory in
to
$WM_PROJECT_USER_DIR/POD
And I modified files and options in Make directory.
here is my output:
make: *** No rule to make target `postProcessing/POD/PODEigenBase/PODEigenBase.C', needed by `postProcessing/POD/PODEigenBase/PODEigenBase.dep'.  Stop.
I cannot understand how wmake runs. anyone help?
I will try to use git to manage the code in $LEMOSEXT to modify the POD code
files:
PODOrthoNormalBase/scalarPODOrthoNormalBase.C
PODODE/PODODE.C
scalarTransportPOD/scalarTransportPOD.C
LIB = $(FOAM_USER_LIBBIN)/libPOD
options:
EXE_INC = \
 -Wno-deprecated \
 -I$(LIB_SRC)/dynamicMesh/lnInclude \
 -I$(LIB_SRC)/triSurface/lnInclude \
 -I$(LIB_SRC)/turbulenceModels \
 -I$(LIB_SRC)/transportModels \
 -I$(LIB_SRC)/finiteVolume/lnInclude \
 -I$(LIB_SRC)/meshTools/lnInclude \
 -I$(LIB_SRC)/sampling/lnInclude \
 -I$(LIB_SRC)/sampling/meshToMeshInterpolation/meshToMesh \
 -I$(LIB_SRC)/fvOptions/lnInclude \
 -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
 -I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude \
 -I$(LIB_SRC)/turbulenceModels/LES/LESfilters/lnInclude \
 -I$(LIB_SRC)/postProcessing/functionObjects/field/fieldAverage/fieldAverage \
 -I$(LIB_SRC)/postProcessing/functionObjects/field/fieldAverage/fieldAverageItem \
 -I$(LIB_SRC)/postProcessing/functionObjects/forces/lnInclude \
 -I$(LIB_SRC)/fileFormats/lnInclude \
 -I$(LIB_SRC)/turbulenceModels/incompressible/LES/LESModel
LIB_LIBS = \
 -lfiniteVolume \
 -lfluidThermophysicalModels \
 -lspecie \
 -lincompressibleTurbulenceModel \
 -lcompressibleTurbulenceModel \
 -lincompressibleRASModels \
 -lincompressibleLESModels \
 -lLESfilters \
 -lLESdeltas \
 -ltriSurface \
 -ldynamicMesh \
 -lfieldFunctionObjects \
 -lgsl \
 -lgslcblas \
 -lmeshTools \
 -lsampling \
 -lfileFormats \
 -lforces \
 -lfvOptions \
 -lLEMOS-2.3.x
chengdi is offline   Reply With Quote
Importing ccm file - Creation of geometry part from boundary crevoise STAR-CCM+ 1 January 10, 2013 03:17
Modelled Part of Reynoldstresses in Channelflow LeFrog OpenFOAM Running, Solving & CFD 0 November 16, 2012 09:01
[ANSYS Meshing] Match Control on multi-body part tdbbz ANSYS Meshing & Geometry 2 September 19, 2012 19:43
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 11:03
how to simulate the rotation of a solid part Jiuan FLUENT 2 July 10, 2010 02:54
