fvMatrix to volScalarField coversion ?
Hi everybody,
I'm try to use the combustion model class of openfoam, it has a member function that returns the source therm for species equations (Reaction rate): virtual tmp<fvScalarMatrix> R(volScalarField& Y) const = 0; If I understand well, this funcion is overloaded with the calculation way provided by reaction model for R that is selected at runtime. it function returns a fvScalarMatrix. My question is if I want to define a new volScalarfield, for example, Rates, It is possible to utilices this fvScalarMatrix and define a volScalarField , exists any form to make this conversion ? Any advice will be graatly appreciated, thanks in advance Felipe |
Hi Felipe,
I have the same problem. Have you succeed? cheers, Xu |
As you know the method is abstract and needs to be overloaded. But what you are trying to achieve is not clear to me. If you want a volScalarFeild, then you can just look for where R has been called and use the input argument of it. You already have that volScalarField (y), why convert it from R? |
You have to multiply by the respective field to get volScalarField from fvMatrix (check how it is used in Qdot function in singleStepCombustion.C). Basically, you need to do
Rates = R(Y) & Y; |
