The meanings of diag( ), source( ), psi( )
Like Tree4Likes
  • 1 Post By cfd_explorer
  • 1 Post By sleepdeprivation
  • 1 Post By santiagomarquezd
  • 1 Post By sharonyue
Old   March 16, 2011, 06:25
Default The meanings of diag( ), source( ), psi( )
Xuan Cai
cfd_explorer is on a distinguished road
I am using the solver"porousSimpleFoam" to run simulations on a domain including porous media.
In the UEqn.H, the momentum equation is implemented as follows:
// Construct the Momentum equation
tmp<fvVectorMatrix> UEqn
fvm::div(phi, U)
+ turbulence->divDevReff(U)
Then in the file: /src/finiteVolume/cfdTools/general/porousMedia/porousZone.C
we have the following code:
scalarField& Udiag = UEqn.diag();
vectorField& Usource = UEqn.source();
const vectorField& U = UEqn.psi();
Does anyone know the exact meanings of UEqn.diag(), UEqn.source(), UEqn.psi() in details, e.g. what do these functions return? Or could anyone give some hints about that?
Thank you very much
gooya_kabir likes this.
cfd_explorer is offline   Reply With Quote
Old   March 16, 2011, 09:46
Alton Luder III
sleepdeprivation is on a distinguished road
See the source code documentation.
Here is the list of all members of fvMatrix since diag() is inheirited
http://foam.sourceforge.net/docs/cpp...ix-members.php
acs likes this.
sleepdeprivation is offline   Reply With Quote
Old   March 16, 2011, 12:08
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
UEqn.diag(); gives you the diagonal of system matrix, UEqn.source(); the source term (both without applying BC's) and UEqn.psi(); a reference to the unknown field. Remember that UEqn is the whole linear system not only the matrix.
Regards.
luiscardona likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   March 17, 2011, 04:56
Xuan Cai
Originally Posted by santiagomarquezd View Post
Regards.
Hi Santiago.
Thanks for your reply.
In the openfoamwiki, I learn that disretization of PDE leads to an algebraic equation in the following form:
AΨ = B
So does
UEqn.diag() mean the diagonal of A, UEqn.source() mean B and UEqn.psi() mean Ψ ?
Old   September 19, 2013, 13:53
Hassan
luckycfd is on a distinguished road
Hi Santiago.
AΨ = B
So does
Please attention to this post. ?
Regards,
Hassan
luckycfd is offline   Reply With Quote
Old   June 17, 2015, 14:13
Dongyue Li
sharonyue is on a distinguished road
So does [/B]UEqn.diag() mean the diagonal of A, UEqn.source() mean B and UEqn.psi() mean Ψ ?
Not really, this is what Im thinking:
For example, if you are discritizing velocity, u will have an symmetry matrix. After discritization, u will have Ax = B, A will be symmetric, Then OpenFOAM will do:
[A.diag()+A.offdiag()] x = B;
A.diag() x = B - A.offdiag() x;
For symmetric matrix, A.diag() will be the diagonal of A, A.offdiag() x will be the source of A. That means if your matrix equation is like this:
A x = 0;
U also have an source() term.
acs likes this.
My OpenFOAM algorithm website: http://dyfluid.com
By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam
We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html
sharonyue is offline   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
