Home > Forums > OpenFOAM Programming & Development
residual control with PISO or NonOrthogonality
Old   June 29, 2015, 09:18
Default residual control with PISO or NonOrthogonality
Daniel Witte
danny123 is on a distinguished road
I want to change the implementation of residual control in OpenFoam somewhat (interDymFoam is used). Right now, if you add additional PISO loops or Nonorthogonal corrections, the abstol is taken from the last iteration. I want to change this that it takes always the value of corrPISO == 1 (for 0 there is no pressure equation) and NonOrthogonalCorr == 0.
In order to do this, I thought to add an object in pimpleControlI.H:
inline bool Foam::pimpleControl::firstPISONOC() const
    return ((corrPISO_ == 1) && (corrNonOrtho_ == 0));
Now, this object can be called in PimpleControl.C similar to "storeIni". My problem is, that the object needs to be stored somewhere (abstol is local). I could do something similar like defining a new object like
residualControl_[fieldI].initialabstol
But where do I have to do this? I found in the C++ guide an object in solutionControl.H:
public:
    struct fieldData
        wordRe name;
        scalar absTol;
        scalar relTol;
        scalar initialResidual;
Can I just add the object to this?
Thanks for the support.
Regards,
Daniel
danny123 is offline   Reply With Quote
Old   July 3, 2015, 05:26
Daniel Witte
I am kind of stuck with this and would appreciate some help. The solution sketched up below does not work. The reason why is simple: the residual control check is done after each PIMPLE loop. At this point, CorrPISO_ and corrNonOrtho_ are reset to 0 (since the loops are finished) and abstol is that of the last matrix iteration.
This means calling a procedure to check for CorrPISO_ or corrNonOrtho_ to be any number is pointless, since they are always constant (= 0) at this point.
This opens up a question: why does OpenFoam has check procedure storeInitialResiduals() specifying CorrPISO_ and corrNonOrtho_ (among others) if these numbers are 0 anyway? It would be sufficient to check for corr_.
There are two initial residuals stored, the very first one (called first) and, as said the last. I would need the first of each PIMPLE step as residual. I checked if this residual is saved somewhere or if I can save it by overwriting a number within e.g. the application solver. Unfortunatly, the residuals are protected and cannot be overwritten.
The best way to do what I want would be the use the variable sp.first().initialResidual() and update after each PIMPLE loop. But this does not seem to work. It is only saved the very first PIMPLE loop. Can anybody tell me, where this is done? I would like to change this, but I do not find any first() object in solverPerformance.C. Is there a list of residuals stored?
Regards,
Daniel
Old   July 3, 2015, 10:12
Daniel Witte
So, I figured it out finally. The solverPerformance object is a list that can be read out. So, all that was needed is to find the right row where to find the information. In pimpleControl.C instead of
            const scalar residual = = sp.last().initialResidual();
you replace by:
            scalar residual;
            label spSize = sp.size();
            if ((sp.first().fieldName() == "p_rgh") || (sp.first().fieldName() == "p"))
                 residual = sp[spSize-nCorrPISO_*(nNonOrthCorr_+1)].initialResidual();
            else
                 residual = sp.last().initialResidual();
So, the initial residual of the 1st PISO loop (no non orthogonal correction made yet), will be picked for residual control.
This works for interFoam, where the outer loop is alpha1Eqn and there inner loops are for p_rghEqn only, but should work for other solvers too (I did not test this) as long as the pressure is designated p_rgh or p.
Regards,
Daniel
Thread Tools
Trackbacks are On
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
