wall roughness in OpenFOAM
I want to give roughness for wall in OpenFOAM
how should I give this???? what is the difference between nutURoughWallFunction and nutkRoughWallFunction and when I'm using following t type nutURoughWallFunction::Ks; value uniform 0.001; type nutURoughWallFunction::Cs; value uniform 0.5; it produces following error Unknown patchField type nutURoughWallFunction::Cs for patch type wall |
- nutkRoughWallFunction
http://www.openfoam.com/documentatio...0.html#details This boundary condition provides a turbulent kinematic viscosity condition when using wall functions for rough walls, based on turbulence kinetic energy. The condition manipulates the E parameter to account for roughness effects. Parameter ranges: roughness height = sand-grain roughness (0 for smooth walls) roughness constant = 0.5-1.0 Example of the boundary condition specification: Code:
myPatch Ks sand-grain roughness height Cs roughness constant -------------------------------------- - nutURoughWallFunction [http://www.openfoam.com/documentatio....html#details] This boundary condition provides a turbulent kinematic viscosity condition when using wall functions for rough walls, based on velocity. Example of the boundary condition specification: Code:
myPatch roughnessHeight roughness height roughnessConstant roughness constant roughnessFactor scaling factor |
function
Do you know the exact equation for turbulent kinematic viscosity based on the two wall functions?
