Extract subset from array
Like Tree1Likes
  • 1 Post By Ivan
Old   August 1, 2015, 10:09
Default Extract subset from array
Ivan
Ivan is on a distinguished road
I would like to perform a simple operation in OpenFOAM. I have a scalarList of n elements, V, and I would like to define a new reference list which points to a subset of V, i.e. all elements from V[k1] to V[k2]. Is there an easy and eficient way to do it? I have seen there is a "subset" function in ListOps.H, but I am still confused in how to use it.
Also, in a similar way, is V is a 2D array, how do I extract all the values of, let's say, the kth column?
Ivan
Ivan is offline   Reply With Quote
Old   August 4, 2015, 18:26
Ivan
Ok, found the solution. Let's say the new vector is called Vsub. Then you need to write,
SubSet<scalar> Vsub(V,size_of_subset,start_index); // V is of type scalarList
Vsub will not be a copy of the subset, but a pointer, which is exactly what I wanted.
You could obtain the same defining directly a pointer using standard c++ programming, but that is not safe as there is no check on the list bounds.
OpenFOAM will perform the size check instead (i.e. in Full Debug mode), which is what I wanted, plus other possible advantages of using OpenFOAM classes =).
mbookin likes this.
TimeVaryingMappedFixedValue best practice to extract subset points and fields podallaire OpenFOAM Running, Solving & CFD 6 May 21, 2014 10:25
[General] Contour plot: celldata2pointdata dmaz ParaView 1 April 28, 2014 16:05
[snappyHexMesh] Extracting a subset of features vkrastev OpenFOAM Meshing & Mesh Conversion 1 December 20, 2012 17:46
[General] extract Ids of point subset from a give triangular surface nacaairfoil ParaView 1 September 18, 2012 12:19
ODETest.C Compiling failed in version 1.6 sxhdhi OpenFOAM Bugs 4 April 27, 2010 05:36
