commsType in foam-extend 3.2?
Dear all,
I finally spared some time to install foam-extend 3.2 and test IHFOAM in it. Happily enough, everything compiles out of the box without any changes from previous versions. I also encountered the same problems as in versions 3.0 and 3.1: running in parallel fails due to commsType being set to blocking. (See http://sourceforge.net/p/openfoam-ex...swak4foam/123/ ). The solution that I have been using until now is the one outlined here: https://openfoamwiki.net/index.php/C...orted_Versions Basically, changing in the commsType in $WM_PROJECT_DIR/etc/controlDict by nonBlocking, used to make the trick. However, in version 3.2, controlDict has been replaced by controlDict-EXAMPLE. Changing the value there, does not work, copying the file over and naming it controlDict does not work either. Any solutions to set commsType in 3.2? Thanks! Pablo |
Updates:
I've traced the problem back to foam-extend-3.2/src/foam/db/IOstreams/Pstreams/Pstream.C, where the way that commsType is set has changed: Code:
// Default commsType Code:
OptimisationSwitches Best, Pablo |
changing commsType to 'nonBlocking'
I know this is a little bit old thread,but I had the same problem. I got the follwong error during parallel running of a case of simpleIbFoam. Code:
Fatal error in MPI_Recv: Message truncated, error stack: Code:
OptimisationSwitches Thank in advance. Thamali |
