Temperature dependent incompressible viscosity model
Old   October 14, 2015, 12:11
Default Temperature dependent incompressible viscosity model
Nikolai Tauber
niko0807 is on a distinguished road
Dear Foamers,
I am currently working on a temperature dependent viscosity model for a modified solver based on simpleFoam and buoyantBuossinesqSimpleFoam.
I am planning on using the powerLaw viscosity as base for modification. Therefore, I have made a copy of it to:
OpenFOAM/user-2.3.x/src/transportModels/incompressible/viscosityModels/nuTemperature
I have changed the filenames to
nuTemperature.C
and
nuTemperature.H
Furthermore in Make/file I have
nuTemperature.C
LIB = $(FOAM_USER_LIBBIN)/libusernuTemperature
and in Make/options
EXE_INC = \
	-I$(LIB_SRC)/transportModels/incompressible/lnInclude/ \
	-I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS =
	-lfiniteVolume
Then I have run wmake and added
libs 			("libusernuTemperature.so");
to my test case controlDict, but when I run my solver I get the error
Build  : 2.3.x-6b18d98df2bc
Exec   : nuTemperatureSimpleFoam
Date   : Oct 14 2015
Time   : 18:05:36
Host   : "hulk2.iha.dk"
PID    : 34454
Case   : /home/dan/run/151009singleCylinder_tvsf_testCase
nProcs : 1
Create time
Duplicate entry powerLaw in runtime selection table viscosityModel
#0	/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x27) [0x7f076e59a207]
#1	/usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so(_ZN4Foam14viscosityModel31adddictionaryConstructorToTableINS_15viscosityModels8powerLawEEC1ERKNS_4wordE+0xce) [0x7f076e91ce1e]
#2	/home/dan/OpenFOAM/dan-2.3.x/platforms/linux64GccDPOpt/lib/libusernuTemperature.so(+0x15ee9) [0x7f0769871ee9]
#3	/home/dan/OpenFOAM/dan-2.3.x/platforms/linux64GccDPOpt/lib/libusernuTemperature.so(+0x18d66) [0x7f0769874d66]
Create mesh for time = 0
Reading thermophysical properties
Reading field T
Reading field p
Reading field U
Selecting incompressible transport model nuTemperature
--> FOAM FATAL ERROR:
Unknown viscosityModel type nuTemperature
Valid viscosityModels are :
5
BirdCarreau
CrossPowerLaw
HerschelBulkley
Newtonian
powerLaw
    From function viscosityModel::New(const volVectorField&, const surfaceScalarField&)
    in file viscosityModels/viscosityModel/viscosityModelNew.C at line 53.
FOAM exiting
^Z
[10]+  Stopped                 nuTemperatureSimpleFoam
Can someone please see where the problem is?
niko0807 is offline   Reply With Quote
Old   October 14, 2015, 12:41
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It is not enough just to rename file, you have to correct this piece of code:
public:
    //- Runtime type information
    TypeName("powerLaw");
in .H file (nuTemperature.H in your case). Put nuTemperature instead of powerLaw there.
UPD. And surely you have to rename class.
alexeym is offline   Reply With Quote
Old   March 2, 2017, 09:08
Emery
TemC is on a distinguished road
Hi foamers,
I'am working with simpleFoam, and I have implemented a new viscosity model based on the Herschel-Bulkley model.
Through the forum I found several disussions (and documents) about the implementation of a new viscosity model in OpenFOAM.
I followed all the tips and steps that are suggested there, but I still don't manage to run a case with my new viscosity model. I always got the error message posted by "niko08/07", suggesting that my new viscosity model is not valid.
Can somebody give a step by step workflow to handle this issue? Any help would be well appreciated.
Thanks in advance, and have a nice week.
Regards.
TemC is offline   Reply With Quote
Temperature dependent Viscosity using Power-Law shikamaru OpenFOAM Running, Solving & CFD 3 January 6, 2015 01:47
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
icoUncoupledKinematicParcelFoam: temperature dependent viscosity 90nash OpenFOAM Running, Solving & CFD 5 March 26, 2014 23:43
Temperature dependent now-newtonian viscosity mozafarie FLUENT 2 March 22, 2014 00:19
Temperature dependent Cp: JANAF tables vs Debye model antb OpenFOAM Running, Solving & CFD 1 August 26, 2013 16:57
