layer addition deletion in parallel
Old   February 9, 2010, 04:33
Default layer addition deletion in parallel
Kedar Jathar
kedarj14 is on a distinguished road
Hello :
I am trying to use layer addition deletion in parallel. The case is working in serial. The case runs in parallel too, however I am not able to post process it properly.
1. Using reconstructPar
reconstructPar utility works till the time directory until the cell count is same as original. Once a cell layer is added the reconstruct par fails. It searches for a file pointProcAddressing, which is not available in the results.
2. ParaFoam
ParaFoam can read the mesh in the individual processor directories. It also shows that the layer are added and deleted. However it crashes if I try to read the pressure and velocity fields.
Has anyone encountered this problem before ? Any solutions, suggestions will be very helpful.
Thanks
Kedar
kedarj14 is offline   Reply With Quote
Old   April 20, 2011, 06:33
Kedar Jathar
Originally Posted by kedarj14 View Post
Hello :
2. ParaFoam
Thanks
Kedar
We need to use reconstructParMesh before running reconstructPar
Old   December 20, 2012, 01:45
u22
Anthony Nitski
u22 is on a distinguished road
This is old post, but i have question. What solver and which OF version you used for layerAR? For me, in 1.6ext I can not get to work adding layers in dieselEngineDyMFoam....So maybe i must to downgrade...
u22 is offline   Reply With Quote
Old   November 10, 2015, 13:06
Roberto Ribeiro Schor
rrschor is on a distinguished road
Anthony,
did you manage to run in parallel?
Best regards,
Roberto
rrschor is offline   Reply With Quote
Old   November 11, 2015, 02:41
u22
Anthony Nitski
Originally Posted by rrschor View Post
Anthony,
Best regards,
Roberto
No, i had to use OF 2.x. There is no layerAR in it.
layer addition deletion, mdm, parallel, reconstructpar
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
How to use the engine solvers with layer addition and removal francesco OpenFOAM Running, Solving & CFD 2 March 19, 2009 03:29
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
