chtMultiRegionSimpleFoam + incompressible thermo type |
November 16, 2015, 09:56 |
Rep Power: 10 |
Hello!
I'm new here and I hope I found the right forum for this topic. Please let me know if I should post my question somewhere else. And here we go: I simulate a heat exchanger with water on the one and air on the other side. I know I can use chtMultiRegionSimpleFoam for that (that’s also what I’m doing right now) by setting water in the constants folder to incompressible. By doing so I use all the equations for compressible flow for water except that I set the density to constant. Now my question is: Is it physically correct to do so? I mean, of course if I set the density to be constant the equations of conservation should become the same in the compressible and incompressible case, but is there something that I'm missing? I assume yes cause there must be a reason why for incompressible solvers like simpleFoam different equations are being used with a transport model (instead of a e.g. basicRhoThermo). Does anybody have experience with this and knows if the error that I introduce by using chtMRSF that way is negligible? Thak you so much for reading this post. I would be very grateful for some ideas Best Kiki |
November 17, 2015, 04:41 |
Rep Power: 10 |
Anyone? Or is the reason for the usage of different equation in the incompressible case that they are easyer to be solved?
Best Kiki |
November 17, 2015, 04:54 |
Vineet Bhola
Rep Power: 10 |
I don't have much experience into programming part of the solver but seems like this might help.
http://www.cfd-online.com/Forums/ope...egionfoam.html Thanks Vineet |
November 17, 2015, 04:57 |
Rep Power: 10 |
Thank you Vineet, that was really helpful!
Cordialement. |
November 17, 2015, 05:04 |
Rep Power: 10 |
Thank you Guys. I know that threat but I found no answer to my question in that link.
Any ideas? Kiki |
January 1, 2019, 00:15 |
Shiromani Chandra
Rep Power: 7 |
Hey Taukiki,
I am also trying the same thing. It has been quite a while since you posted this question! I just wanted to ask whether you got any answer. Please respond it will be of great help! |
[Other] simulation of closing the gate using moving mesh | simin_ds | OpenFOAM Meshing & Mesh Conversion | 8 | April 12, 2019 05:49 |
Time step continuity error | lpz_michele | OpenFOAM Running, Solving & CFD | 0 | October 12, 2015 06:05 |
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
SimpleFoam - instable simulation | Specialist | OpenFOAM Running, Solving & CFD | 17 | August 12, 2014 04:52 |
interFoam/kOmegaSST tank filling with printStackError/Mules | simpomann | OpenFOAM Running, Solving & CFD | 3 | February 17, 2014 17:06 |
