adding energy equation to interFoam
Like Tree7Likes
  • 2 Post By Elham
  • 1 Post By wyldckat
  • 2 Post By kebsiali
  • 2 Post By Mojtaba.a
Old   November 26, 2015, 01:29
Default adding energy equation to interFoam
Elham
Elham is on a distinguished road
I am trying to add energy equation to interFoam. So I made a new library called myincompressibleTwoPhaseMixture and a solver called interTempFoam as suggested by http://www.wolfdynamics.com/images/c...erTempFoam.pdf.
I could successfully compile the library in openFoam 2.3.0 but I cannot compile the solver. I got the following error:
/usr/bin/ld: cannot find -lmyincompressibleTwoPhaseMixture
collect2: error: ld returned 1 exit status
make: *** [/home/elham/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/interTempFoam] Error 1
I have attached my library and solver. I will be really appreciate if anyone can give me clue.
Mojtaba.a and rasool_soofi like this.
Elham is offline   Reply With Quote
Old   November 28, 2015, 09:15
Retired Super Moderator
Bruno Santos
Quick answer:
  1. The library package in "Make/files" has defined the name "libmyincompressibleTransportModels".
  2. The solver is looking for the name "libmyincompressibleTwoPhaseMixture".
  3. Can't see the difference? Try seeing it like this:
Elham likes this.
Old   November 28, 2015, 11:23
ali alkebsi
kebsiali is on a distinguished road
http://www.cfd-online.com/Forums/ope...interfoam.html
you can check the 6th and 7th discussion in this link where i explained what to add to the make file of your solver and modified library
Elham and Mojtaba.a like this.
kebsiali is offline   Reply With Quote
Old   December 7, 2015, 08:30
Pay
Perry Uhlig
Pay is on a distinguished road
you can have a look at my thread. I got interTempFoam compiled using OF 2.4.0.
Unfortunately the new solver creates temperature fields that contain obvious mistakes.
http://www.cfd-online.com/Forums/ope...m-2-4-0-a.html
Pay is offline   Reply With Quote
Old   March 4, 2016, 11:44
Question error while compiling libaray
Rimsha
block is on a distinguished road
Hi all,
nice to see so much discussion and support,
I am trying to compile the lib after altering it using this guide to implement temperature equation in interFoam
however I am unable to wmake my lib as it keeps giving me this error.
This is what happens when i command wmake
wmake libso >logs
Make/options:7:12: warning: backslash-newline at end of file [enabled by default]
 LIB_LIBS = \
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file singlePhaseTransportModel/singlePhaseTransportModel.C
Making dependency list for source file transportModel/transportModel.C
Making dependency list for source file viscosityModels/HerschelBulkley/HerschelBulkley.C
Making dependency list for source file viscosityModels/BirdCarreau/BirdCarreau.C
Making dependency list for source file viscosityModels/CrossPowerLaw/CrossPowerLaw.C
Making dependency list for source file viscosityModels/powerLaw/powerLaw.C
Making dependency list for source file viscosityModels/Newtonian/Newtonian.C
Making dependency list for source file viscosityModels/viscosityModel/viscosityModelNew.C
Making dependency list for source file viscosityModels/viscosityModel/viscosityModel.C
make: *** No rule to make target `Make/linux64GccDPInt32Opt/myIncompressibleTwoPhaseMixture/myIncompressibleTwoPhaseMixture.C.dep', needed by `Make/linux64GccDPInt32Opt/myIncompressibleTwoPhaseMixture/myIncompressibleTwoPhaseMixture.o'. Stop.
This is how my make>file looks
LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleTransportModels
here is my make>option looks
EXE_INC = \
    -I.. \
    -I../twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
    -ltwoPhaseMixture \
    -lfiniteVolume \
I dont know what the link error is, sorry if this is too basic because i am new to OpenFOAM.
help will be much appreciated
Thanks
Rimsha
Last edited by wyldckat; March 6, 2016 at 10:34. Reason: Added [CODE][/CODE] markers
block is offline   Reply With Quote
Old   March 6, 2016, 16:17
Bruno Santos
Quick request @Rimsha: Please provide the source code package that you're using. I ask this because it will be a lot quicker to help you if you do this.
In addition, please keep in mind that you seem to be using OpenFOAM 3.0, which has some big differences from OpenFOAM 2.3.0, including in its build process.
Old   March 6, 2016, 16:25
Rimsha
Hiya, thank you very much for your reply, it is highly appreciated.
May i know where i can find this source code, do you mean the lib code that i am trying to wmake?
I am sorry if this sounds stupid but i am very new to this software.
Old   March 6, 2016, 16:32
Bruno Santos
Yes
Quick example, run the following command from within your source code folder:
wclean all
cd ..
Then package the folder by running something like this:
tar -czf the_package_name.tar.gz  the_library_folder
rename the tilted names and then attach the "the_package_name.tar.gz" file in your next post.
Old   March 6, 2016, 16:35
Rimsha
Yes
wclean all
cd ..
thank Bruno Santos,
unfortunately i am not in the office at the moment however first thing tomorrow morning i will do that and attach the file.
Old   March 7, 2016, 16:20
Question
Rimsha
Yes
wclean all
cd ..
Library trying to make >>incompressible.tar.gz
Hiya, I have attached the lib above.
Basically I am trying to add temperature heat capacity to interFoam however there are two approaches one could take
Method 1:
before editing solver and adding the equation, I have to alter "incompressibletwophasemixture" file however instead of altering the file, i got an additional file called twoPhaseThermalMixture.C and H where new variable related to heat capacity (cp) Prandl number and diffusion coefficient (kappa in the file). This file is then linked to "incompressibletwophasemixture" file using the file in make folder and also in "incompressibletwophasemixture.C" it is included in the beginning.
However with this approah I am getting error where nothing in C file of twoPhaseThermalMixture.C is being recognized when i wmake libso.
i attach the log file log.txt
Method 2
In second method I have followed this tutorial
In this approach you can edit "incompressibletwophasemixture.C" and "incompressibletwophasemixture.H" to include all the new variables that are included in twoPhaseThermalMixture.C and twoPhaseThermalMixture.H in method 1. once that is done you can just make this library again however this also gives ridiculous errors therefore i am not sure what to do.
Hope I was able to explain my problem well, I am extremely grateful for your effort to help me.
My OpenFoam is 3.0.1 i am not sure if that is the case why this library alterations are not working.
here are the files for 2nd approach and the log file is included
incompressible_Ap2.tar.gz
Rimsha
Old   March 28, 2016, 11:11
Bruno Santos
Hi Rimsha,
Sorry, but only today did I finally managed to take a look into your questions. Nonetheless, I've checked other posts you've made since then and it seems that you've already solved your problem?
I'm referring to the posts you made in the following threads:
Best regards,
Bruno
Old   January 29, 2017, 14:14
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Just to make it clear of future readers, the thread suggested by Ali solved my problem.
Just try adding this code into your options file:
-L$(FOAM_USER_LIBBIN) \
Adios!
hwangpo and rasool_soofi like this.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
Adding Energy Equation for porousSimpleFoam yesaswi92 OpenFOAM Programming & Development 20 April 13, 2018 08:17
Definition of energy equation using UDF aestas Fluent UDF and Scheme Programming 15 April 28, 2015 03:33
Questions about the energy equation aestas Fluent UDF and Scheme Programming 5 April 6, 2014 11:28
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
