How to create a list with particle properties from a specific cell?
Hey everyone
I'm trying to implement a stochastic particle-particle collision model in OpenFOAM-2.3. For that, I want to create lists with determined particle properties for every mesh cell. For example, The diameter distribution inside a cell. With that I'm able to determine the average particle diameter, maximum and minimum diameter inside a cell and so on. These statistics are necessary to create the fictitious particle used in this collision model. Someone can help? :confused: Best regards :) |
I'm also facing similar problem in fluent. Did u find a way.
Thanks. |
Every particle/parcel is linked with each cell. Check out the particle class. Parcels used for kinematic tracking offfer the diameter (KinematicParticle.H): Code:
protected: And they wrap around the basic particle Code:
template<class ParcelType> For you, this means that the particles/parcels themselves already contain the information you require for the collision model. Also, your sentence: Quote:
Number of particles at each cell
Hi foamers,
I am using solidParticle class and I am trying to calculate the number of particles in each cell at certain times. I want to combine all of the particles in a cell. Any suggestions? Thanks, |
There is already something similar in Foam::KinematicCloud<CloudType>::theta()
which will calculate the particle fraction in the cells via theta[cellI] += p.nParticle()*p.volume(); This can for example be used in sprayFoam.C with alpha = parcels.theta(); You could duplicate this function and change this to sumParticles[cellI] += p.nParticle(); you will get the desired Number of particles. best regards Andy |
You are right. However, the diameter distribution information for each cell cannot be got by this way. Kind Regards, Ping |
Do you mean that parcels.theta() represents the particle volume fraction? But when I use this in my case, in some areas, the value of parcels.theta() is more than 1. I dont know what does it mean, can you explain it again? And what should I do to get the volume fraction of the particles? |
Yes, exactly... when your sum of particle volumes is more than the cells volume, you'll get a theta > 1. This can happen easily when you are not calculating paircollision of particles.
You can also try a dispersion model, which spreads the particles where the volume fraction is high. found here: Lahey, R.T., Lopez de Burnsdano, M., Jones, O.C., 1993. Phase distribution in complex geometry conduits. Nuclear Engineering and Design 141, 177–201. Best regards |
