Customized fvOptions-class for momentum source: no rule to make target |
December 10, 2015, 06:02 |
Peter
Rep Power: 10 |
Dear Foamers,
I would like to create my own fvOptions-class to introduce a momentum source term. (Unfortunately, none of the existing classes help me.) Approach: I copied the 'actuationDiskSource'-folder, I renamed the files and names inside from 'actuationDisk...' to 'newSource...', I added the 'newSource.C'-file in '$FOAM_SRC/fvOptions/Make/files', then I tried to compile it with 'wmake' and 'wmake libso'. Result: All files which exist for e.g. 'actuationDiskSource' are created for 'newSource' too, like in 'platforms/linux.../...'. BUT: It doesn't work. -1.) Compiling message: Code:
... no rule to make target ».../OpenFOAM-3.0.0/platforms/linux64GccDPInt32Opt/src/fvOptions/new.dep« ... required from ».../OpenFOAM-3.0.0/platforms/linux64GccDPInt32Opt/src/fvOptions/new.o« ... Why? -2.) Running simpleFoam with a 'fvOptions'-file (adapted from 'actuationDiskSource') returns an error, that the type is not known: Code:
--> FOAM FATAL ERROR: Unknown Model type newSource Does anyone has an idea? That would be very cool!!! =) |
December 10, 2015, 14:52 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: For the first issue, you have the following in the output:
src/fvOptions/new.dep In addition, try cleaning before building: Code:
wclean libso wmake libso |
December 11, 2015, 02:52 |
Peter
Rep Power: 10 |
Thanks!!
Further information: This was my file 'Make/files': Code:
... $(derivedSources)/newSource/newSource.C // new fvOptions ... I changed the comment to Code:
... $(derivedSources)/newSource/newSource.C /* new fvOptions */ ... So, your were right, the reason was the 'new' inside 'Make/files'... Thanks for your help! |
mapFields Error with snappyHexMesh Source Added Layers | sherif35 | OpenFOAM Pre-Processing | 0 | September 29, 2014 17:01 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
