January 13, 2016, 05:46 |
Error when runing blockMesh
adhi makayasa
Rep Power: 11 |
Hi All,
after type blockMesh in the terminal to get a message like this /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : blockMesh Date : Jan 13 2016 Time : 17:29:38 Host : "yasa-X455LD" PID : 4656 Case : /home/yasa/OpenFOAM/yasa-2.3.0/run/newairFoil nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /home/yasa/OpenFOAM/yasa-2.3.0/platforms/linuxGccDPOpt/lib/libmyIncompressibleRASModels.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE --> FOAM Warning : From function dlLibraryTable:pen(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libmyIncompressibleRASModels.so" fileName::stripInvalid() called for invalid fileName logerror~ For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) How to fix it? Please help, this is my final assignment. Thanks |
January 13, 2016, 06:45 |
adhi makayasa
Rep Power: 11 |
this is
Make/files mySpalartAllmaras.C LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleRASModels Make/options EXE_INC = \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude LIB_LIBS = When iam compile using wmake libso is allright. But when i run blockMesh i get ERROR message like on the top |
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results | nicholas.jones | OpenFOAM Meshing & Mesh Conversion | 3 | May 16, 2019 09:52 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] External flow around cube with blockMesh | Woody8 | OpenFOAM Meshing & Mesh Conversion | 0 | March 31, 2015 14:54 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
