Herschel Bulkley Papanastasiou model
Like Tree2Likes
  • 1 Post By Amith Gubbi
  • 1 Post By ignayars
Old   April 25, 2016, 04:55
Default Herschel Bulkley Papanastasiou model
Amith Gubbi
Amith Gubbi is on a distinguished road
I am trying to simulate a herchel-bulkley model of blood through a 3D pipe and have implemented the Papanastasiou regularization. The model seems to work fine for nonNewtonianIcoFOAM(transient solver)but when i try to simulate it in a steady state solver(simpleFOAM), I get a floating point exception. I have attached the case setup with the log file and also the papanastasiou model that I have implemented.
The Papanastasiou regularization is according to the following paper:
http://www.bsr.org.uk/rheology-revie...-Mitsoulis.pdf
Any suggestions regarding fixing this is appreciated.
Thanks,
Amith
mahdi_izadi likes this.
Amith Gubbi is offline   Reply With Quote
Old   May 28, 2016, 07:29
Default Re:Herschel Bulkley Papanastasiou model Reply to Thread
Yaroslav
ignayars is on a distinguished road
I think some initial velocity distribution should set up. Like that:
internalField   uniform (0 0 1);
It resolves problem with iterations. But simpleFoam speed convergence is very low.
I dont think that length of tube should be so big to find solution.
I hope you found solution, please share it
With best regards,
Yaroslav
ignayars is offline   Reply With Quote
Old   March 2, 2017, 09:24
Emery
TemC is on a distinguished road
Hi Amith Gubbi,
Can you please tell me how you managed to build AND use your new viscosity model?
I'am working with simpleFoam, and I have implemented a new viscosity model based on the Papanastasiou regularization. But each time I try to run a case using my new viscosity model, I got an error message suggesting that my new viscosity model is not valid (attachments).
Thanks in advance for your time, and have a nice week.
Regards.
TemC is offline   Reply With Quote
Old   March 31, 2017, 02:24
Default Papanastasiou regularization
Yaroslav
Hi!
Here my realization of Papanastasiou regularization of HerschelBulkley. Tested for OF4.1.
Use this post to implement the code.
Originally Posted by open View Post
I'm posting here since this is one of the most recent cries for help over "valid viscosityModels are" error message.
Put the new transport model into the source directory:
/opt/openfoam4/src/transportModels/incompressible/viscosityModels/newModel
newModel.c
newModel.H
If the newModel includes:
addToRunTimeSelectionTable...
Then update the make file by appending the newModel to:
/opt/openfoam4/src/transportModels/incompressible/make/files
From the transportModels dir, run:
wmake libso incompressible
Or, compile the individual library (wmake libso from the source folder) and then add the model to controlDict by appending the line:
libs ( newModel.so );
Permissions error...
Use su or sudo bash. Do not forget to source the openfoam toolbox:
 . /opt/openfoam4/etc/bashrc
With best regards,
Yaroslav
Old   July 28, 2021, 05:06
mohammad
mostanad is on a distinguished road
Originally Posted by ignayars View Post
Hi!
With best regards,
Yaroslav
But you are still using \eta_0 as maximum viscosity? Is it really needed?
mostanad is offline   Reply With Quote
Coupling RPI wall boiling model with population balance model in Fluent softice2006 Fluent Multiphase 1 April 19, 2023 02:09
Herschel Bulkley model Problem emad FLUENT 6 September 12, 2018 13:35
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation Pathak FLOW-3D 0 August 24, 2009 06:34
