Adding New phaseCompressible Turbulence Model
Hello Foamers,
i try to add Rzehak's extension for bubble induced turbulence to the kOmegaSST model. See for example here: http://www.qucosa.de/fileadmin/data/...nhein-ICMF.pdf following the common procedure for adding new turbulence models: - copy similar model (e.g kOmegaSSTSato) - renaming files and functions - adding Make/files + Make/options - compiling using "wmake libso" i got the following error multiple times for all functions/objects: (example: ) kOmegaSSTRzehak.C:162:6: error: ‘virtual void Foam::RASModels::kOmegaSSTRzehak<BasicTurbulenceMo del>::correct()’ previously declared here void kOmegaSSTRzehak<BasicTurbulenceModel>::correct() AND kOmegaSSTSASRzehak.C:40:1: error: redefinition of ‘Foam::RASModels::kOmegaSSTRzehak<BasicTurbulenceM odel>::kOmegaSSTRzehak(const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&, const Foam::word&)’ kOmegaSSTRzehak<BasicTurbulenceModel>::kOmegaSSTRz ehak same procedure still works for "normal" compressible/incompressible turbulence models but not for phaseIncompressible/phaseCompressible models. I tried it with version 2.3.0/3.0.x and actual Openfoam-dev: same error in all versions. Guess it has something to do with template formulation of the models. Has anyone a suggestion how to add new phaseCompressible turbulence models to actual versions of OF? Thanks to the community and best regards Stefan |
just to make sure i didn't made a basic linking mistake here are my Make/files Make/options:
files: Code:
EXE_INC = \ |
I did a quick search and as we suspected the problems comes from compiling the template class directly instead of initiating it. Additionally, compiling such library isn't that straight forward even in OF original code. Here what I found when I tried to compile a new phase compressible turbulence model; you need to add new file which calling a macro to initialize the template class like; Code:
$FOAM_SOLVERS/multiphase/twoPhaseEulerFoam/phaseCompressibleTurbulenceModels/phaseCompressibleTurbulenceModels.C Code:
//copy all the header files and here is a copy of the options file which I used, Code:
EXE_INC = \ I tested by linking it to a tutorial case for twoPhaseEulerFoam and the solver recognized it and started to complain about the wallDist fvSchemes. But having said that, there is another problem. The solver runs but complains first by showing a very long error. The main points of this error are; Code:
I hope that will help you to fix this problem. Best wishes, Hassan Kassem |
Hello Hassan,
thank you so much! Your method solved the problem. The solver recognises the new turbulence model. I'm still faced to the same errors as you but i will post a solution here as soon as i found one. Thank you again, this was really a great help! :D Best regards, Stefan |
This problem comes from ``makeBaseTurbulenceModel`` macro which has two functions, initialize the base template class then add it to run time table. Using ``makeBaseTurbulenceModel`` as it is means re-adding the base models to the run time table again which cause this error. The following modified macro should solve the problem. Just replace everything (keep the header files) in ``myphaseCompressibleTurbulenceModels.C`` Note: This macro could be used for LES as well. Best wishes, Hassan Kassem Code:
#define createBaseTurbulenceModel( \ |
Does your solution is still valid for OpenFOAM 3.0.x?
I notice that adding a new turbulence model in OpenFOAM 3.0.x is not so straightforward than in previous version |
This solution for OpenFOAM-3.0.0 and upward unless they changed again. |
Thanks for your answer. I follow your steps, but I failed when I compiled the solver with the command wmake libso. In fact, I get:
make: *** No rule to make target 'Make/linux64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.C.dep', needed by 'Make/linux64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o'. Stop. I am pretty sure that it is a very basic error, but since I am at the beginning with OpenFOAM and with creating a new turbulent solver, I have not been able to solve it up to now. Thanks for your answer. |
2 Attachment(s)
You maybe need to run wclean first. In case, it did not wok, I'm attaching here two examples which you can use for comparison.
Bw, Hassan |
Hi Thanks for your help. Now I am able to compile it. Just last questions, when I run my solver, the case is not able to recognize the new turbulence model. I add at the end of my controldict the command libs ("libmyphaseCompressibleTurbulenceModels.so"), as you suggested in your guide; in fact, the new model is not put in the directory /OpenFOAM-3.0.x/src/TurbulenceModels/phaseCompressible/RAS to mantain pure the installed version of OpenFOAM.
By doing so, I obtained an error concerning the fact that my model has not been recognized among those available. |
The library name is incorrect, it should be exactly the same as in Make/file. For example for the attached mymixtureKEpsilon model
libs ("mymixtureKEpsilon.so"); |
Up to now I succeded in compiling my new turbulence model. It works without errors. Nevertheless, I notice this warning: --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /cineca/prod/opt/applications/openfoam/3.0/openmpi--1.6.4--gnu--4.7.2/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/lib/libcompressibleTwoPhaseSystem.so: undefined symbol: _ZN4Foam2fv10optionList5debugE --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "mymixtureKEpsilon.so" If I use this model in my case, the solver correctly selects my turbulence model. However, this warning appears whenever I run checkMesh, decomposePar or other command that has to do with calling the controlDict. Even though, I obtained results I would like to solve this problem and avoid warnings. Thanks in advance for your help |
I am trying to compile my dynamicsmagorinsky model in openfoam 3.0.x but getting following error :
symbol lookup error: /home/adlak/OpenFOAM/adlak-3.0.x-cfdsupport/platforms/linux64Gcc49DPInt32Opt/lib/libdynamicSmagorinsky.so: undefined symbol: _ZNK4Foam9LESModels18dynamicSmagorinskyINS_15EddyD iffusivityINS_18ThermalDiffusivityINS_27Compressib leTurbulenceModelINS_11fluidThermoEEEEEEEE2CkEv If any one can help then it will be a great help for me. I followed steps given here http://hassankassem.me/posts/newturbulencemodel/ |
It is hard to debug such error without the code. BTW, are you using CFD-support windows version? |
[/QUOTE][/QUOTE][/QUOTE][/QUOTE]
It is OpenFoam-in-box based on openfoam 3.0.x for ubuntu. Give me ur email id. i will mail u my code. I have modified dynamickeqn model to make dynamicSmagorinsky model. |
Did you guys figure this out? I am having the same issue at run-time. I had just assumed it was something silly in my code. Curious to see if you guys found anything useful? What was the issue? Schuyler |
If it a common case, could anyone upload the code here with a test case or at least the steps to reproduce the error? It will be helpful for the community to keep a record of this case here.
Schuyler, could you please confirm which OF version have you tested? is it CFD-Support version? Best wishes, Hassan |
2 Attachment(s)
This is just a simple case to see if the model would run. I have run this model before using OpenFOAM 2.3 but wanted to update it to the newer version using the new format for the turbulence src. Schuyler |
Hello Schuyle,
Thank you for uploading the code it helped a lot. The problem of your model is a missing defination of one function, namely Code:
tmp<volScalarField> fmu(const volScalarField& chi) const; Please keep us updated! Best wishes, Hassan |
