Baldwin Lomax - Zero Equation Turbulence Model
Old   June 6, 2016, 21:20
Default Baldwin Lomax - Zero Equation Turbulence Model
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hello experts in OpenFoam.
I need some assistance in coding a zero equation turbulence model i.e. Baldwin Lomax.
http://www.cfd-online.com/Wiki/Baldwin-Lomax_model
I have tried to modify the two equation turbulence models and one equation models to remove the PDEs and convert this into a fully algebraic zero equation model without much success.
Another Idea I have is to start from Laminar so that I don't have to remove the PDE's. What is the best way to go about it?
Also if any one else has done some work or know more information please help me out.
With kind regards
Shereez
shereez234 is offline   Reply With Quote
Old   June 7, 2016, 21:54
shereez234's Avatar
M Sereez
Hello;
I have made some progress in removing 2 PDE's from a 2-equation model. But Baldwin Lomax uses y+ (yPlus) for it's execution. Wall distance y_ is easily incorporated in to the code but does any one know how I can incorporate yplus in to my source code without having to redefine the whole calculation of yplus again...
Thanks
Old   June 9, 2016, 12:58
shereez234's Avatar
M Sereez
Going forward;
now I am stuck here:
I have a function
F= a * b * y_ * C
I would like to return the Ymax which is the corresponding y_ while F = Fmax (i,e, maximum of function F)
I tried
while ( F == Fmax)
return y_(Fmax);
But it doesnt work. Can somebody please help me
Thanks
Old   June 10, 2016, 01:31
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey shereez,
Your code looks horrible
I can probably help you, but I need more information.
What are a, b, C and y_ ? Functions or constants?
Philipp.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   June 10, 2016, 14:13
shereez234's Avatar
M Sereez
Originally Posted by RodriguezFatz View Post
Hey shereez,
Philipp.
tmp<volScalarField> Baldwin_Fake::L() const
     return f_ * y_ *(1 - exp(yPlus/Aplus_));
 tmp<volScalarField> Baldwin_Fake:: Fnum(const volScalarField& G1) const
   return  (y_ * G1 * (1 - exp(yPlus/Aplus_)));
 tmp<volScalarField> Baldwin_Fake::Fmax(const volScalarField &Fnum) const
      tmp<volScalarField> Y1 = max
      (Fnum, 1e-40);
     return Y1;
tmp<volScalarField> Baldwin_Fake::Ymax(const volScalarField& Fmax, const volScalarField& G1) const
                 return  (Fmax / (G1 *(1 - exp(yPlus/Aplus_)) ));
  tmp<volScalarField> Baldwin_Fake::Fkleb(const volScalarField& Ymax) const
      tmp<volScalarField> H;
       (1 +5.5 * pow(((y_ * Ckleb_)/Ymax),(6)));
       return pow(H,-1);
  tmp<volScalarField> Baldwin_Fake::YmaxFmax
    const volScalarField& Ymax,
 ) const
      return (Ymax * Fmax);
 tmp<volScalarField> Baldwin_Fake::Fwake(const volScalarField& YmaxFmax, const volScalarField& Fmax, const volScalarField& Udiff, const volScalarField& Ymax) const
  //   ((YmaxFmax, Cwk_ * Ymax * ((Udiff * Udiff))/Fmax)),1e-40);
        return max ((((sqr(Udiff))/Fmax) * Cwk_ * Ymax), YmaxFmax );
 tmp<volScalarField> Baldwin_Fake::nut_Inner(const volScalarField& L, const volScalarField& G1) const
     return ((sqr(L)) * G1 * scalar(1.2));
 tmp<volScalarField> Baldwin_Fake::nut_Outer(const volScalarField& Fkleb, const volScalarField& Fwake) const
     return (Fwake* Fkleb * Ccp_ * K_ * scalar(1.2));
 tmp<volScalarField> Baldwin_Fake::yCrossOver(const volScalarField& nut_Inner, const volScalarField& nut_Outer) const
    if (nut_Inner = nut_Outer)
        return 0.0;
Yeah that wasnt the real code. Some how I am able to get the Ymax now. At the moment I am stuck in a position with yCrossOver (the last function in the code) nut_Inner = nut_Outer as you can see from above. I need to return thee min(y_) while nut_Inner is equal to nut_Outer. Do you think I need a bool function to do this?
Thanks for the help I am not an expert in C++ coding
Old   June 14, 2016, 18:40
shereez234's Avatar
M Sereez
  tmp<volScalarField> Baldwin_Edit2::Ymax(const volScalarField& Fmax) const
        return y_(Fmax);
I have tried several different ways. I would like to know how I can return the value of wall distance y_ when Fmax = maximum.
Is there any one who can help me?
Old   June 21, 2016, 02:13
Philipp
Hi again,
Sorry I forgot about this thread...
Well, I don't understand your code or I don't understand the model!
Can you post the whole code? It looks like you use y+ as a constant...
Implement an les turbulence model pante OpenFOAM Programming & Development 19 December 5, 2014 16:16
Zero equation turbulence model gives better result?? Sanyo CFX 10 June 26, 2011 10:58
Baldwin Lomax Turbulence Model kharati Main CFD Forum 0 February 7, 2009 11:30
Baldwin lomax turbulence model masoud Main CFD Forum 1 February 7, 2009 11:29
Reynolds transport, turbulence model, etc Beginner Main CFD Forum 1 January 7, 2009 05:36
