Change values in patchField
Old   July 1, 2016, 03:02
Question Change values in patchField
Justin Wiegmann
SirIsaac90 is on a distinguished road
Hi Foamers!
I want to change a C-code a little bit. Therefore, I want to change only the values of
const scalarField rhow =
            patch().lookupPatchField<volScalarField, scalar>("rho");
which are greater or less than a specific value. As an example, one could describe it like this:
\rho =
\begin{matrix} 1.18 & 1.18 & 9 \\ 1.18 & 1.18 & 11  \\ 1.18 & 1.18 & 1.18  \end{matrix}.
This should the be set to
\rho =
\begin{matrix} 1.18 & 1.18 &  1.18 \\ 1.18 & 1.18 &  1.18 \\ 1.18 & 1.18 & 1.18  \end{matrix},
because i want to set all values > 2 to 1.18.
This should be done with an if-statement.
Anyone, who could help me with this? This would help me a lot.
Regards
JW
SirIsaac90 is offline   Reply With Quote
Old   July 6, 2016, 08:30
Jerry
Jerryfan is on a distinguished road
scalarField& rhow =
const scalar& value=2;
const scalar& valuenew=1.18;
forAll(rhow, index)
if (rhow[index] > value)
rhow[index] = valuenew;
instead of using a const scalarField, you have to change it to a reference or just normal variable. This should work fine.
Jerryfan is offline   Reply With Quote
Getting internalField values from a patchField aabbasi59 OpenFOAM Programming & Development 11 October 30, 2019 07:29
Periodic (rotational)flow: a bit of confusion concerning reference values Mr.Goodcat FLUENT 0 March 22, 2016 07:31
strange u+ values with LES-Smagorinsky matejmuller OpenFOAM Running, Solving & CFD 2 January 8, 2016 06:08
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
Change system of units? Joern FLUENT 1 February 9, 2004 11:13
