Home > Forums > OpenFOAM Programming & Development
interFoam symbol lookup error??
Old   July 5, 2016, 14:58
Default interFoam symbol lookup error??
ArielJ
arieljeds is on a distinguished road
Hi there, I've done something very frustrating with the interFoam solver, or possibly the incompressibleRASModel library.. I'm getting this error when I try to use interFoam:
interFoam: symbol lookup error:  /home/ariel/OpenFOAM/ariel-2.4.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so:  undefined symbol: _ZTIN4Foam14incompressible8RASModelE
I tried making my own turbulence model and realised that I accidentally saved it with the same name in the same library as the current incompressibleRASModel. I fixed this in the Make/files code (new line: LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleRASModels) and then did
wmake libso
And all compiled correctly. Following that, I went back into the original turbulenceModels/incompressible/RAS directory and did:
wclean RAS
wmake libso RAS
Which seemed to go ok, and then finally I tried to recompile interFoam with Allwmake, which appears to go ok as well. I'm getting so frustrated, I can't see where the error is coming from after these steps!! Can anyone help me please??
arieljeds is offline   Reply With Quote
interfoam, libso, rasmodel, symbol lookup error, wmake
Thread Tools
Trackbacks are On
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
